Home Logo
Alex Duff Posted on Aug 20, 2017
Vivint security system says the batteries are weak in one of my smoke detectors. I replaced the batteries 2 times but system continues to alert us. Can I remove that one completely out of the system?
Jason Dobson
Level 1:
  • Contributor 4 Answers
  • Posted on May 15, 2019
Jason Dobson
Contributor
Level 1:
Answers
Questions
0
Helped
1847
Points
5
After you put it back up, hold the test button in so you hear three beeps, three times. Or remove it from the base plate and put it back.
If that doesn’t work, call Vivint and have them walk you through removing and re-adding it back into the system.
Alternatively they might need to send a Technician
Katina Romo
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 29 Answers
  • Posted on Aug 20, 2017
Katina Romo
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
29
Questions
0
Helped
3819
Points
74
Try to change the battery on the system its self.
5 Related Answers
A
Anonymous
  • Posted on Jul 17, 2008
SOURCE: smoke alarm/carbon monoxide detector
I have a First Alert Smoke Detector Model SA 86RAC.When I changed the Battery today it beeps.How do I fix this problem?
Anonymous
  • 15 Answers
  • Posted on Mar 09, 2009
SOURCE: 1996 Toyota Celica remote security system no longer works
Hi, Contact your dealer and get instructions for reprogramming your remotes. When a security system loses power for an extended amount of time the programming for the remotes are lost.
Anonymous
  • 65 Answers
  • Posted on Jul 01, 2009
SOURCE: We have smoke detectors that are hooked up to
when you replaced the batteries it may unprogramed
Anonymous
  • 34 Answers
  • Posted on Oct 25, 2009
SOURCE: smoke detector won't stop chirping.
it may need to be cleaned or it is bad may need to be replaced
Anonymous
  • Posted on Mar 29, 2011
SOURCE: my smoke/carbon monoxide detector keeps
My Smotec 3786A indicates not to install it in above 85% humidity.
One of my three seems to go off annually or so and this is what
recently put it down to. I was making an espresso coffee on the
stove and it generates a lot of steam and off goes the fire alarm.
I did change the battery to no avail.
What causes continual beeping
With some smoke detectors, this indicates a low battery. Try putting in a new battery and see whether it stops beeping. If it doesn't add a comment to this question and specify the make and model of your smoke detector.
Oct 06, 2014 • Home
1helpful
Two first alert smoke detectors go off for no reason. All are on 110 with good batteries. Have had these for approx. 12 years with no problems until now when 2 of the 7 have gone off many times in the last...
There may be dust built up in the sensing chamber. This can cause alarms to go off for no reason. Try vacuuming the alarm off particularly around the sensor if the cover is removable. These alarms should be replaced however, as they are more than 10 years old.
1helpful
I could not get to battery compartment of the first alert smoke alarm. Please tell me how to replace with new battery.
Hold the entire smoke detector,turn it to the left or right,u will able to take the smoke detector out.The battery compartment is in the back.
2helpful
One of the alarms is peeping every 30 seconds. Why and how do I stop it?
Normally this means the smoke detector's battery or batteries are getting weak and need to be replaced. Since your detector incorporates carbon monoxide detection it could also mean the sensor that measures CO is going bad. Most units with CO detection have a life expectancy of 8-10 years. If your unit is that old I would suggest replacing it. Hope this helps.
1helpful
I replaced the 9 voly battery to the Smoke and
Can you pleas ensure that you have cleaned the unit as well. If it is not broken, that would be the probable cause. You can ask your local fire dept. to assist. They do that for free :-)
Cheers
TeaCii
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
Replaced battery still beebing
Still beeping,brand new battery?Hook near a kitten?Cooking might set it off.Cooking or smoking set it off all the time.
Smoke alarm/carbon monoxide detector
Top Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Home Expert? Answer questions, earn points and help others
