SOURCE: Whirlpool fridge freezer
trying to open door?? does it feel as if top wants to open ad bottom of door is being stuck shut? or mabye a package of frozen food has shifted of a shelf and is holding the door shut, if so brute force will solve that one.if it feels like held at bottom sounds as if youmight have a clogged defrost drain tube.drain water backing up onto freezer plor and holding door shut. even then forcing door open is only way then removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over.
SOURCE: LG DLE5977 Electric Dryer
Below are some solutions that other customers have cited. The control board seems to have a glitch in it, so I would take it back and get a replacement. New product is covered by a factory warranty or a dealer replacement guarantee.
My husband and I just BARELY bought an LG Electric Dryer. I'ts model #DLE2516W. As soon as you hit the power button, "check filter" comes on. The right after that, the error code "Te1" flashes and it does nothing but beep. Clearly, the filter has NOTHING in it because I've never run a load of clothes thru it. When I look in the troubleshooting section of the owners manual, it tells me that this means that the thermistor is open and needs to be replaced. But I'm confused as to why a BRAND NEW dryer already needs a part replaced. Can ANYONE please help me. I have lots of laundry to do. Haha!
Comment by Amanda02, posted on Sep 11, 2007
Well... we took it back to Home Depot and they are replacing it. i was trying to fix it because it takes 3 weeks to get a new one. They don't have any in stock!! And it takes 3 darn weeks to get a new one.
SOURCE: soap dispenser does not open
You have a water supply problem. If you don';t get enough water then the dishwasher pump cannot pumpit up high or strong enough to dissolve the soap[. Your water valve screen may be clogged.
SOURCE: ice dispenser won't work, light won't work.ge side by side fridge
A GE uses a 12 volt bulb . It will not come on , if you went and bought a bulb with the same receptical end . HAS to be a 12 volt .
