20 Most Recent
VeriFone VX510 Questions & Answers
Verifone vx520 tamper please enter pasword
if you have a tamper you may need to get it replaced, try this press enter key and if it takes you to a menu press set up, enter password, do you have the password? 1 alhpa alpha 66831 ( the alpha key is above the 2) then press more until you see date and time, change date and time see if this fixes tamper or press red x until you get antoher screen or press f2/f4 same time enter password and then clock change time if this does not work you need a new terminal
How do I check credit card activity of a prior date
if you are asking if you can do this on your VX510, the answer is you can not check prior activity for any credit card on a credit card machine, that would require contacting the bank that issued the credit card. if it is your card they will provide information, if not your card, you will need owner of card to call.
My verifone vx510 is displaying
Simultaneously press [F2] & [F4].Key in 1, Alpha, Alpha, 66831 and press [Enter].Select CLOCK [F3].Key in the Year, the Month and the Day and then press [Enter]. Do not press [Enter] between these values, the terminal will automatically populate the appropriate fields as they are entered. Use the down arrow to scroll down to check/adjust the time. Key in the hour, using military format (ex: 3 p.m. = 15), then key in the minutes and press [Enter] to complete and return to Menu 1. Do not press [Enter] between these values, the terminal will automatically populate the appropriate fields as they are entered.when finish Select Restart [F4].
Why is screen indicating download is needed?
www.monerisusa.com/support/~/media/Files/.../
Vx510_qrg.ashx
VeriFone Vx510 with SoftPay. Quick Reference ... their PIN, and encourage them to protect their PIN. ERROR ... the terminal screen. ... PINpad display is blank: See "PIN Pad Error" ... the ALPHA key (repeatedly if necessary until the desired.
How do i reboot
To Reboot the
Verifone VX510 or VX570 terminal you will press the "F2" and "F4" buttons at the same time. When it prompts you for the password, you will enter it (this depends on which credit card provider you use) and it will bring you to a "sys mode menu 1" screen. The "F4" option should give you a "RESTART" option, which is the same as rebooting the machine.
V # 8020 have new battery & cord. displays comes
if you still seeing the backlight of the display, your lcd maybe bad in shape. the display assembly needs to be replaced. or maybe some other problem causing it too. if you still needs help on your verifone8020, call (775)358-2922 look for randy and maybe we can help you. thanks
What do I do about a RAM chksum error G2 on our Verifone V510?
Probably the best way to correct this problem is to clear the RAM and download your app. again. In other words start over with a clean slate. After doing this you still have the same problem, you may need to open the machine and disengage the battery. This would clear the RAM, but you would then need to clear the tamper error message. Call Frank @ 775-338-6634
How do I unlock vx510?
By unlock is this for the keypad, if so press the number 8 and enter the password of 1 alpha alpha 66831 enter and then NO- this will unlock the keypad, if there is another lock please submit that question
LOAD PAPER
hold in hand, with the loose side down, roll this into cradle, hold about 3 inches of the loose paper in your hand and close door, no feeding needed. tear off excess
Vx 510 tcp
no connected to internet, check all connections, reboot modem and terminal by unplugging power and Ethernet cables wait 1 min plug back in.
