Computers & Internet Logo
S
Sylvia Reyes Posted on Jun 20, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ok so i just got this compaq presario 1255. its running windows 98 and used aol dial up. does it have a wireless setting and if so how do i do it. cause im going to scream, so please help me.
richie46
Level 3:
Top Expert:
  • Compaq Master 12,962 Answers
  • Posted on Jun 20, 2017
richie46
Compaq Master
Level 3:
Top Expert:
Answers
12962
Questions
Helped
2946394
Points
58151
Scream all you want - no one is going to hear you. You need to install a wireless adapter inside your PC and also set up a wireless network.
What's the most current OS I can use to replace Windows 98 on a Compaq Presario 1277 laptop?
You might be able to find a stripped down version of XP or put Windows NT on it. Those are my best guesses. NT will let you use newer versions of some browsers as well. Mostly Explorer
I have a dell desktop with wireless connection, there is also a wireless router connected to the dell to send a wireless connection to a laptop in the household. in a bedroom in the house is a compaq...
As you mentioned, your Compaq Presario MV520 is using Windows 98 OS. As we all know, dial-up connection is the only available internet connection at that time so obviously Win 98 has dial-up LAN connection. However, you wanted to have wireless connection on that PC so you need to install a wireless adapter to that PC. First of all, most wireless adapters that are being used for desktop PC are wireless USB adapter, so you need to have a USB port on that PC. And also, you will need to check if the software for the wireless adapter will be accepted by the PC because since the PC is using Win 98 OS, we are not sure if the firmware of the wireless adapter will be compatible to the PC. Basically, my answer would be not possible.
Before to start laptop appair the following error: 0270 real time clock error. save to disk file not found save to disk feature is disabled run phdisk for information.FILE:create new. ...
compaq is HP so best is to ask them, there, now here.
RTC error mean , the RTC coin cell is dead.
all PCs this old are dead battery ,
RTC= real time clock chip says IM DEAD, but is battery dead ,..
remove the coin cell, and put in a new one.
end story.
then set time .
best is to set time in BIOS setup. 1st.
this Compaq is 18 years old now. or 126 dog years.
id , push it off a cliff on the 4th July with fireworks. and all.
let me guess its XP the VIRUS magnet.
some this old are windows 98
a hopeless case there, no? no support, no books and no updates.
the books at HP are long gone
so now all books are , sold by horders. $$$
it can be costly and dangerous to deal with folks like that.
the book you lost , , the answer is on page 18
seen here
see coin, remove it and put in new one. end story.
https://www.manualslib.com/manual/30167/Compaq-Presario-Presario-1255.html?page=21#manual
2answers
Is it possible to set up a wireless connection on a Presario 1275 laptop running Win 98?
Yes, but fairly difficult. Try to find a wireless pcmia card with teh original disk that should have a program that will install a utility and o the setup for you.
Compacq Presario CQ60-419WM, can't connect to AOL.
Its true that you need broadband to use the router and then need the router for wireless networking.
I have an old Compaq 1260 running Windows 98.I want to connect to the internet to up grade but I cant because of the dial up motum.I have a netgaer wireless router in the home that runs all my new laptops....
Ok you need to see if you have a wireless adapter to the laptop if you don't have one then you can buy one for less than 10 quid...Once you installed it then you need to input your network key code(if you have any sort of secutiy on your network which I suggest you have)..Hope this helps and it's a 10min job...
1helpful
2answers
Invalid systme disk. Replace the disk and press any key
its domnickr,
its so we can not install xp in model 1255 it will spoils your hard disk all you can install win98 ED 2 only..... so its wise not to try it and reinstall using win 98 install disk. if format is not possible do format using Fdisk command.
step 1 :enter dos floppy
restart ur lap enter from insulation option.
chance boot perority to floppy disk ie Shift +.
restart lap
enter fdisk in commant
format using instruction for any help mail at [email protected]
2answers
The quick restore dosen`t work
What operating system you are using before installing windows xp. If it is windows 98, Your restore cd will restore windows 98. if you want to restore to factory settings pls boot from the restore cd and format the harddisk. Becareful, this will erase your entire data on the harddisk which cannot be recover. If you are using licenced (not pirated) windows xp boot from it and reinstall windows xp so that you can run the os smoothly. But in either case becarefull when you are formating, it will destroy entire data and you may endup in soup. feel free to revert back for further quiries
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
