It is set in the room in the correct temperature range and voltage outlet.
SOURCE: Frigidaire gas range oven does not go up to correct temperature
It sounds like the thermostat is off. This would be the first place I would check.
SOURCE: Dehumidifier not removed moisture from air
There are many reasons for a dehumidifier to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
SOURCE: 0GE Dehumidifier AHM65LKM1 not taking moisture out of the air
heatman101
SOURCE: Honeywell Natural Warm Moisture Humidifier Is On But No Steam?
I have the same problem and I have 2 of them fairly new. I can't seem to find out what the problem is either.
Stumped?????????
SOURCE: I have a 2 year
Don, unless your dehumidifier is a Low temperature model, that very well may be the problem.
The air temp in a basement at floor level is colder than that chest level. Dehumidifiers don't work well at temperatures at 40 degrees F or less. Raising the unit up off the floor on to a sturdy table, counter top, etc, that is strong enough to handle it's weight, plus a full tank of water, will generally solve the problem. The higher up you can safely put it, the better. Also, lower the humidity extraction level to 35%. As 50% is just not low enough in a basement application.
Hope this helps you to solve the problem.
