Cars & Trucks Logo
a
angie vanarsdall Posted on Apr 19, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My son took his car to Ramona tire shop because his 2006 mustang was overheating thay said the problem is this
For 1400.00 we can fix it so they put a water pump in new thermostat changed all the hoses a pressure tested it now job is done and paid for and the car is still overheating and loosing fluid took it back they said they fixed it drove home and the same thing happened took it back ok they pressure tested it and changed the ressavore cap they its fixed that was yesterday today same problem took it back they pressure tested agin now they say its the motor both gaskets and it will cost 2500 what should he do they offerd to pay for some of the labor to fix it don't forget less then a week ago he paid them 1300 rhat they said was wromg with what would you do we need help help
Bill Boyd
Level 3:
Top Expert:
  • Cars & Trucks Master 53,816 Answers
  • Posted on Apr 19, 2017
Bill Boyd
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11951468
Points
172802
They are not qualified to repair a wheel barrow
your son is wasting his money and time dealing with them
the first test for overheating is a compression test to check for head gasket or cracked head/s
water pumps do not cause over heating as they are only water circulators
thermostats often do and if not installed correctly will still cause a problem
find yourself an accredited service center with experience on your make of vehicle and get a proper diagnosis and quote
2006 w219 Mercedes ( CLS 500) 86,000miles took to corner tire ski to change tire.. soon as I got home- parked- and returned to get in my car.. suddenly the front end ( driver side / not the replaced tire)...
The best solution you'll get from books at www.reliable-store.com
These are books containing info on repair, service, troubleshooting, parts info, assembling dissemble, removal, error/fault codes, wiring diagrams and everything on any vehicles cars, atv, trucks. forklifts, boats, excavators etc
Hello I have a1995 Mustang that tore up and I took
yes as when you change an ignition switch it has to be sync to the computer so it knows the correct keys are being used and the car is not being stolen.
Our 2000 Mustang continually needs to be battery jumped. Took to shop, they said not battery or starter. They said it's Ford car alarm that is draining battery. Now what?? How do I disconnect
If the shop could find the problem, why
can they not resolve it ?
Need a different shop, if there is such
a place these days, that can actually
fix something
99 mustang rear tire bent inward?
Does the mustang have independent (IRS) axel or the solid 8.8 rear axel?
Does the fuel inertia switch on a 2006 ford mustang gt reset automatically or does it require manual reset
Since this trips to prevent fuel from pumping in a collision, it is made to be manually reset. The device on a son's Ford used to trip occasionally on our rough easement. On his car it was located behind a panel in the trunk.
2006 JEEP WRANGLER 2 DOOR WITH 33'S SHAKES AT 45MPH. TOOK IT TO THE SHOP AND THEY SAID IT WAS A BAD TIRE. TIRES ONLY HAVE ABOUT 8000 MILES ON THEM
It HAS been known to happen before. I've put BRAND NEW tires on a vehicle to find that there was one who had a bad spot in it....the belt inside the tire was split and it made a flat spot FROM the factory
2answers
Right tail light on 2006 mustang remains on after car is shut.
Hi, I have the same issue with my 06 GT. other lights have done the same thing. of course the dealership says if they cant duplicate the problem, they cant do anything. I did talk to another mechanic at a "good" shop and he said it sounded like the BCM module ( body control module). I may put a new one in and see if that fixes it.
Tire sensor fault
it should b able to reset with the trip counter push till u get to tire and reset
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
