Miscellaneous Logo
??????? ???????? Posted on Apr 12, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tcu 3128 man - Miscellaneous
solver2010
Level 3:
  • Master 923 Answers
  • Posted on Apr 20, 2017
solver2010
Master
Level 3:
Answers
923
Questions
0
Helped
192881
Points
2907
1helpful
2answers
Hello. I have problems with a 2008 MAN TGL 8.180. I get error code TCU 04153-10 and 04172-03 and air pressure too low and the car will not go into gear. Do anyone have same problem?
All the codes are here. Use CTRL+F and type in 04153 and then 04172.
https://www.techtransa.lt/MAN_klaidu_kodai.pdf
Power Supply Pressure Module on wheel 6.
No Pressure Build Up during Pump activation.
How to fix them though, I have no idea, I only find stuff. Commercial trucks are a bit outside the expertise of Fixya. Try one of the MAN forums or justanswer.com
More here
https://www.google.com/search?q=MAN+TGL+8.180%2C+TCU+04153-10
Tcu 3117 man
RE: MAN TCU DIAGNOSIS 03117-00 tcu code 3117 means clutch self adjustment which is between 3 common brothers( pressure plate..release bearing and clutch ) but before you decide to change any check the pressure system from the air drier valve into the actuator if its ok
concerning the pressure leakage around the gearbox indicates there is a problem with the zf astronic...sometime even the automatic transmission fluid may also leak its the zf astronic replace or repair if necessary
in addition actuator problem will come up with tcu fault code 3198-08 on the screen
Man tga what is tcu
TCU stands for Transmission Control Unit.
Apr 12, 2017 • Toys
2helpful
LINUX SQUID SERVER IN TRANSPARENT MODE
Dear Friend....
The examples below are based on the discussion of Linux iptables in Chapter 14, "Linux Firewalls Using iptables". Additional commands may be necessary for you particular network topology.
In both cases below, the firewall is connected to the Internet on interface eth0 and to the home network on interface eth1. The firewall is also the default gateway for the home network and handles network address translation on all the network's traffic to the Internet.
Only the Squid server has access to the Internet on port 80 (HTTP), because all HTTP traffic, except that coming from the Squid server, is redirected.
If the Squid server and firewall are the same server, all HTTP traffic from the home network is redirected to the firewall itself on the Squid port of 3128 and then only the firewall itself is allowed to access the Internet on port 80.
iptables -t nat -A PREROUTING -i eth1 -p tcp --dport 80 \
-j REDIRECT --to-port 3128
iptables -A INPUT -j ACCEPT -m state \
--state NEW,ESTABLISHED,RELATED -i eth1 -p tcp \
--dport 3128
iptables -A OUTPUT -j ACCEPT -m state \
--state NEW,ESTABLISHED,RELATED -o eth0 -p tcp \
--dport 80
--state ESTABLISHED,RELATED -i eth0 -p tcp \
--sport 80
--state ESTABLISHED,RELATED -o eth1 -p tcp \
--sport 80
Note: This example is specific to HTTP traffic. You won't be able to adapt this example to support HTTPS web browsing on TCP port 443, as that protocol specifically doesn't allow the insertion of a "man in the middle" server for security purposes. One solution is to add IP masquerading statements for port 443, or any other important traffic, immediately after the code snippet. This will allow non HTTP traffic to access the Internet without being cached by Squid.
If the Squid server and firewall are different servers, the statements are different. You need to set up iptables so that all connections to the Web, not originating from the Squid server, are actually converted into three connections; one from the Web browser client to the firewall and another from the firewall to the Squid server, which triggers the Squid server to make its own connection to the Web to service the request. The Squid server then gets the data and replies to the firewall which then relays this information to the Web browser client. The iptables program does all this using these NAT statements:
iptables -t nat -A PREROUTING -i eth1 -s ! 192.168.1.100 \
-p tcp --dport 80 -j DNAT --to 192.168.1.100:3128
iptables -t nat -A POSTROUTING -o eth1 -s 192.168.1.0/24 \
-d 192.168.1.100 -j SNAT --to 192.168.1.1
iptables -A FORWARD -s 192.168.1.0/24 -d 192.168.1.100 \
-i eth1 -o eth1 -m state
--state NEW,ESTABLISHED,RELATED \
-p tcp --dport 3128 -j ACCEPT
iptables -A FORWARD -d 192.168.1.0/24 -s 192.168.1.100 \
-i eth1 -o eth1 -m state --state ESTABLISHED,RELATED \
-p tcp --sport 3128 -j ACCEPT
In the first statement all HTTP traffic from the home network except from the Squid server at IP address 192.168.1.100 is redirected to the Squid server on port 3128 using destination NAT. The second statement makes this redirected traffic also undergo source NAT to make it appear as if it is coming from the firewall itself. The FORWARD statements are used to ensure the traffic is allowed to flow to the Squid server after the NAT process is complete. The unusual feature is that the NAT all takes place on one interface; that of the home network (eth1).
You will additionally have to make sure your firewall has rules to allow your Squid server to access the Internet on HTTP TCP port 80 as covered in Chapter 14, "Linux Firewalls Using iptables".
Good Luck!
2answers
94 Jeep Grand Cherokee Transmission Problom
1994 is the same as 1997. parts are interchangeable
Firewall is not configered is linux centos
try and go for it..all d best...
Use yum command as follows:
# yum install squid
Output:
Loading "installonlyn" plugin Setting up Install Process Setting up repositories Reading repository metadata in from local files Parsing package install arguments Resolving Dependencies --> Populating transaction set with selected packages. Please wait. ---> Package squid.i386 7:2.6.STABLE6-4.el5 set to be updated --> Running transaction check Dependencies Resolved ============================================================================= Package Arch Version Repository Size ============================================================================= Installing: squid i386 7:2.6.STABLE6-4.el5 updates 1.2 M Transaction Summary ============================================================================= Install 1 Package(s) Update 0 Package(s) Remove 0 Package(s) Total download size: 1.2 M Is this ok [y/N]: y Downloading Packages: Running Transaction Test Finished Transaction Test Transaction Test Succeeded Running Transaction Installing: squid ######################### [1/1] Installed: squid.i386 7:2.6.STABLE6-4.el5 Complete! Squid Basic Configuration Squid configuration file located at /etc/squid/squid.conf. Open file using a text editor:
# vi /etc/squid/squid.conf
At least you need to define ACL (access control list) to work with squid. The defaults port is TCP 3128. Following example ACL allowing access from your local networks 192.168.1.0/24 and 192.168.2.0/24. Make sure you adapt to list your internal IP networks from where browsing should be allowed:
acl our_networks src 192.168.1.0/24 192.168.2.0/24
http_access allow our_networks
Save and close the file. Start squid proxy server:
# chkconfig squid on
# /etc/init.d/squid start
Output:
init_cache_dir /var/spool/squid... Starting squid: . [ OK ] Verify port 3128 is open:
# netstat -tulpn | grep 3128
Output:
tcp 0 0 0.0.0.0:3128 0.0.0.0:* LISTEN 20653/(squid) Open TCP port 3128 Finally make sure iptables is allowing to access squid proxy server. Just open /etc/sysconfig/iptables file:
# vi /etc/sysconfig/iptables
Append configuration:
-A RH-Firewall-1-INPUT -m state --state NEW,ESTABLISHED,RELATED -m tcp -p tcp --dport 3128 -j ACCEPT
Restart iptables based firewall:
# /etc/init.d/iptables restart
Output:
Flushing firewall rules: [ OK ] Setting chains to policy ACCEPT: filter [ OK ] Unloading iptables modules: [ OK ] Applying iptables firewall rules: [ OK ] Loading additional iptables modules: ip_conntrack_netbios_n[ OK ] Client configuration Open a webbrowser > Tools > Internet option > Network settings > and setup Squid server IP address and port # 3128.
See also You may find our previous squid tips useful:
Top Miscellaneous Experts
H Smith
Level 1 Expert
Robert
vince
Are you a Miscellaneous Expert? Answer questions, earn points and help others
