Exercise & Fitness Logo
James Teel Posted on Apr 05, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I clear the E6 code in a Xterra 3.0 treadmill?
Romeo Direzze
Level 2:
Habit-Forming:
New Friend:
  • Expert 58 Answers
  • Posted on Apr 05, 2017
Romeo Direzze
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
58
Questions
0
Helped
23638
Points
178
An E6 or E7 error code is an incline error code. The E7 code means the potentiometer value the console is reading from the lift motor is out of range. This can happen when there is a bad wire harness connection or a damaged wire harness. It could also just mean the incline motor needs to be adjusted back into range. If all wire connections look ok, the incline motor will need to be adjusted.
  1. Turn the power OFF, wait 5-seconds and turn back ON.
  2. Get into test mode and enter through the I/O testing step. This screen will display the potentiometer value of the incline motor. Different models will have different values. Check to see if the running deck is raised to high incline level or if it is at the low level. If the running deck is at a low position press the incline up button. This will cause the incline motor to raise the running deck up. When the deck gets to a mid-level position, press the incline up button a second time to stop the deck. If the running deck is in a high incline position, use the incline down button to adjust the deck to a mid-level position.
  3. Once the unit is in the mid-level position, power the treadmill off for 5-seconds and then power it back ON.
  4. Start the treadmill.
  5. Once the treadmill starts the running deck will move to the level 0 position. If this does not resolve the issue or it will not adjust please contact customer service.
Also note that not all models will have the ability to adjust the incline motor. If the adjustment procedure is not found in the Owner's Manual then contact customer service.
Hi there. I have an Everlast treadmill. I did a running mat replacement and I used it for about 10 minutes then it stopped and showed E6 Error. Any help will be highly appreciated.
Question edited for clarity.
Question moved to 'Everlast Fitness' category.
E6: Insufficient power To clear: Check if voltage is too low or if the controller has been damaged. Replace the controller if necessary.
https://www.dyaco.ca/manuals/Treadmills/Everlast/16005606510-EN.pdf
https://www.google.com/search?q=everlast+treadmill+e6+error
Xterra TR3.0 error code 5
Quoting from XTERRA on website
The E5 Error is specific to the TR2000e and the TR3000e treadmills.
The error code triggers when an object is detected by the folding sensors on the underside of the treadmill. The folding sensors look like small trapezoids: two on the back and two on the front. Make sure there are no foreign objects underneath the treadmill. If no objects are present, inspect the sensors for damage. If the problem persists, please contact customer service.
E6 error code in Vision Fitness t9300
The follow link may help:
http://productload.johnsonfit.com/inc/uploaded_media/8bed1bc924000d07ecaa6d43edec18db/troubleshooting_guide/87fc08ffe3e0caa8a9d3a1b15d59e71d.pdf
The E6 error code means that the signal from the elevation is lost.
E6 Solution:
1. Check the elevation plug connection at the lower board.
2. Check large data cable connection at the lower and upper boards.
3. Calibrate (See engineering mode for specific treadmill)
4. Test/change large data cable (use large data cable information provided in the data cable portion of this Guide).
5. Replace elevation motor
See page 17 on the following link to enter into engineering mode. ENG4 is Auto-Calibration
https://data2.manualslib.com/pdf2/49/4851/485073-vision_fitness/t970hrt_service__manual.pdf?a70bdaa881cbfa6431ecf6d2abc581e6&take=binary
How do I resolve Error 5 on my XTERRA Treadmill
Customer service department 877.654.3837 x4 or fill out a customer service request form.
https://www.lifespanfitness.com/fitness/resources/articles/what-does-your-treadmills-error-code-mean
1helpful
What is the E6 code on a Xterra 3.0 treadmill?
E6 code is normally related to missing/incorrect reading of the signal position of the inclination motor.
My orbit Starstrider T242 treadmill has got an E6 code on it, what can I do
follow this steps and fix it. God bless you
Internal memory error
Console is not able to write and
read the internal memory
Turn off and on again to clear Error 6
E6 error code on lifespan tr200 treadmill
please proceed according and fix it. God bless you
trouble +cause+ solution
E6 Faulty Safety key Check Safety key or switch
Elv. Motor not moving Check Elv. Motor
connections
Elv. Motor screw binding Clean screw, lubricate or
remove obstruction
Elv. Motor out of range Check motor zero position
Elv. Potentiometer Calibrate elevat ion motor
3helpful
F6 CODE ON A BLADEZ TREADMILL
please test the motor see my personal TIPS for motor help. However this is indication, controller failure. see the block diagram too.ipqidqpmpqaaaabjru5erkjggg==12_31_2012_3_35_30_pm.gif12_31_2012_3_36_25_pm.jpg
Error E6 on Healthstream treadmill
If you wish to get some details about treadmill error codes ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Clearing Vision Fitness T9500HRT treadmill Error Code E6
How do I get back to the basic treadmill....it popped up old programs
Top Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
