Ovens Logo
Albert Jr. Bugden Posted on Mar 21, 2017
Frigidaire oven 3 years old temperature rises up by itself to almost broil
Aether R&D
Level 1:
New Friend:
  • Contributor 15 Answers
  • Posted on Mar 21, 2017
Aether R&D
Contributor
Level 1:
New Friend:
Answers
15
Questions
0
Helped
1116
Points
46
More then likely there is a damaged thermal sensor or the unit that controls the temp is damaged or bad.
Testimonial: "Thank you"
  • Albert Jr. Bugden Mar 21, 2017
    Would you change the thermal sensor first Any part stores in Toronto
  • Albert Jr. Bugden Mar 22, 2017
    I called Sears parts and Parts select any other stores you can pick it up
Frigidaire oven temperature unreliable.
Is this an electric oven? Sound like a bad breaker to me if it is.
1helpful
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
Frigidaire oven wont heat up but stovetop and digital all works
Hello angeleyez82 - The EOC (electronic oven control/control board) basically sends power to both the broil and bake elements. As long as the power supply to the range (240VAC) and wiring between the elements is correct, then typically only the element(s) or EOC could prevent the unit from heating. I hope this information helps to some degree.
Westinghouse 662 Oven temp is wrong, by about 100 degree's.
would check to make sure both your broil and bake ignitors are working. On some, but not all, both come on to preheat, and then the broil shuts off. Another, and more likely culprit would be the temperature sensor located in the oven itself. Its the silverish metal rod protruding from the back wall inside the oven. It could be bad and not converting heat/elsectrical signal properly causing the main control to regulate the temperature incorrectly.If the sensor you are talking about is the oven temperature sensor than its just as easy, since you are behind the machine already, to take off the back panal, unplug the sensor and measure resistance there. Either way the resistance should read around 1099-1100 ohms.even a small margine off can cause a major temperature difference.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Older Frigidaire electyri-clean range Model REG 533 * HD
I wish I had a solution for you...unfortunately I don't. However, if you know anywhere I might find a thermostat knob for this model I would be eternally grateful. I've been searching for 2 years for my mother. It's the knob with 5 settings (off, bake, broil, time-bake and clean).
1helpful
GE Profile Stove baking option not working
Possibly the bake igniter, the temperature sensor or the electronic oven clock/control. Does broil mode heat properly or does it run cool also? If broil heats to the proper temperature then the temperature sensor is probably ok. That leaves the ignitor or the controller which takes some more troubleshooting. If it is the controller, we repair them at www.fixyourboard.com.
2answers
Self cleaning
Sometimes, according to what I've seen.  My theory is that the elements are probably covered in grime and this causes the damage.  As far as the control...I don't think that makes sense.
Never use cleaner on the elements..also causes damage.
A typical duty cycle for cleaning is 2- 2.5 hours.  Longer and you could burn them up, too.
Frigidaire Cookstove
Your oven valve that supplys both the gas and the power to the bake and broil burner is your problem part#5303210798
Top Frigidaire Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Kell Le
Level 1 Expert
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
