Cars & Trucks Logo
J
Jim Gilley Posted on Mar 19, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 2004 sea doo with a starting problem. It will turn over 3 or 4 times and then just click. I have a new battery and have cleaned all terminals within reach.
My sea doo is a 2004 GTI LE. Will a bad starter relay act this way?
Vernon Taylor
Level 3:
  • Cars & Trucks Master 7,446 Answers
  • Posted on Mar 19, 2017
 Vernon Taylor
Level 3:
Answers
7446
Questions
0
Helped
1960410
Points
26207
Perhaps.
I suggest you test the theory by bypassing the relay and/or energising the starter motor manually using a jumper lead, a suitable screwdriver or similar or a remote starter switch.
I have a 2004 Sea Doo GTI LE That clicks like a bad batt. I have a new batt installed. Ocassionally it will turn over like it should but only for a second. Any suggestions.
There is a bad connection at the battery terminals or cable connections, check the battery posts and cable terminals are shiny clean, check the earth cable is clean and tight at the chassis , check the cable to the starter motor is tight and clean, if all is good there the starter may be at fault.
2004 mercury mountneer turn ignition panel lights up but engine wont start?
1 With your headlights on before inserting key Do your headlights shine OK ?
2 Do they Dim or go out when you turn the key?.
3. Do you get any clicking sound when you turn the key??
Results
1 if not possible bad battery - or battery cable to battery, engine and ground points connections bad/need cleaning possibly.
2 If they go Out - See number 1 . Also, Started may be enganged t engine and stuck.
3. No Clicking = #1 possible.
2answers
96 sea doo has a problem with the battery light staying on anyone no why ?
check voltage going to battery it is most likely low
How to start a 2005 sea doo challenger
These vessels have a kill switch with a cord that you have to wear on the arm in case you fall off. I would be looking for a problem with that kill switch
Jet ski
too rich, adjust thehigh idle screw
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
