SOURCE: Savin C6045(Ricoh C3260) popping SC400 and SC496
either the id sensor is dirty or defective, or the music sensor is defective.
The bottom left portion of the display gave
the error message:
Waste Toner Bottle 1 Almost Full. Please call service.
They were still able to print,
however this message would not go away.
To Fix:
Power down the printer using
the normal shutdown method.
Open the top front door.
Remove the cover directly below
the 4 toner cartridges.
The removable cover below the
toner cartridges is actually the Waste Toner Bottle.
Bring this to the dumpster.
There is a round, clear-plastic tab on the underside of the "bottle". Remove this.
Shake the bottle around over the dumpster.
Continue until all the toner has been removed.
Push the clear plastic tab back in place.
Wipe off all toner residue before putting it back into the printer.
Put the waste toner bottle back into place. Power on the Savin. Confirm the message no longer appears and that users are able to print.
