Cars & Trucks Logo
C
Chuck muir Posted on Feb 15, 2017
Ez go headlight wiring and fuses - Cars & Trucks
Nissan Navara won't start , not getting any ignition lights , no headlights nor door locks , the house lights work alone ... the battery is good . Was driving and the van just cut off ..
you blew a fuse link at the battery wire.
It is a lower gauge wire say a 10 gauge in the normal 18 gauge wire. If you get an over load the 10 gauge wire melts breaks the circuit to protect the system.
Wire in a new fuse link from parts store. When you P/U part they can tell you exact location of fuse link on wire. It's EZ
to wire and EZ to find it will look all melted for about 8 inch.
Hope this helps Mike
2helpful
2answers
I have a 2000 Monte Carlo SS, low beam headlights do not work. I have changed the headlight relay, headlight switch, checked all fuses, checked all bulbs, and cleaned the ground wires. What next?
As you can see from the diagram, the orange wire is voltage and fuse protected. The fuse circuit is hot all the time. Not only check the fuse, check the fuse circuit for voltage.
Headlight keeps blowing
hi,
use the process of elimination, disconnect both headlights at the bulb and put another fuse in it and see if it blows. if the fuse blows without the headlights plugged in then its the wiring to the bulbs. if the fuse doesn't blow while the headlights aren't plugged in try plugging the lights in one at a time to see which headlight or socket is shorted. possibly corrosion at body to ground connections near the headlights, you may not see the corrosion, remove the ground wires and sand those ground wires down..
2helpful
NO LOW BEAM, EVERYTHING CHECKS OK . I HAVE CHECKED ALL BULBS AND FUSES
The simple answer may be that the low beam side is burnt out. Replace the bulb.
However, if both headlights have stopped working when switching to low beams, there may be a problem with the relay or the switch itself. If the cost of a relay is low for your car, it may be less expensive to simply replace that component than to have it diagnosed in a repair shop. Replacement of the switch requires some disassembly of the steering column or dash in most vehicles.
This is how to fix the low beam..
1.Check your fuses. The plastic panel covering the fuses should have a diagram detailing what each fuse covers. If yours is missing, or unlabeled, check your owner's manual, or a Hanes(tm) or Chilton(tm) repair manual. Often if a headlight is not working, it is the result of a blown fuse. Fuses have a wire running through them that will melt when too much current is run through them. If the fuse is blown, the wire will be broken. If the fuse for the headlight you are working on has an intact wire, it is likely the problem lies elsewhere.
2.Swap the headlight for its twin. If your left headlight does not work, put the light from your right headlight in its place. If it works with the other headlight in place, your headlight bulb is dead, and needs to be replaced.
3.If this does not work, try using a voltmeter on the plug for the bad headlight. Turn on the ignition, and turn the headlight switch. If the voltmeter shows no current, then either your switch or the wiring leading to the headlight has gone bad.
4.If replacing your headlight switch does not solve the problem, then there is a break in the wiring leading to the headlight, and the wiring will need to be replaced.
Thanks for contacting fixya.com
Keeps blowing fuse in fuse block ,burnt block and wire also burnt headlight switch replaced headlight switch and still blowing fuses lights will not work at all now
The positive wire in the headlight circuit is shorted to ground someplace, you have to check the wire by following it from where it connects to the headlight back to the switch and then to the fuse block
2helpful
1999 ford expedition: Removal of dash/headlight switch?
yes you can. the head light switch come out real ez it un plug on the back side .and the cluster come out in one pices
2answers
Both headlights out... fuse fixes it temporarily
Are you absolutely positive you are installing the correct amp fuse ?
I think headlights on Subaru's run thru a relay, which could be bad.
Here's a how-to that may help.
Headlights Not Working Try These Fixes
1helpful
Lighting systems
Dear Sir/Madam,
  1. Check your fuses. The plastic panel covering the fuses should have a diagram detailing what each fuse covers. If yours is missing, or unlabeled, check your owner's manual, or a Hanes(tm) or Chilton(tm) repair manual. Often if a headlight is not working, it is the result of a blown fuse. Fuses have a wire running through them that will melt when too much current is run through them. If the fuse is blown, the wire will be broken. If the fuse for the headlight you are working on has an intact wire, it is likely the problem lies elsewhere.
  2. Swap the headlight for its twin. If your left headlight does not work, put the light from your right headlight in its place. If it works with the other headlight in place, your headlight bulb is dead, and needs to be replaced.
  3. If this does not work, try using a voltmeter on the plug for the bad headlight. Turn on the ignition, and turn the headlight switch. If the voltmeter shows no current, then either your switch or the wiring leading to the headlight has gone bad.
  4. If replacing your headlight switch does not solve the problem, then there is a break in the wiring leading to the headlight, and the wiring will need to be replaced.
Thanks
Good Luck
"Don't Forget to rate the solution"
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
