My k850i is not working. when i try to turn it on, it does nothing. well it does it, tries to power on the buttons light up and it vibrates and the camera has a blue light around it.
Hi i had same problem,download update service from se e follow the instruction,its free and 100% working for me
make swure that the battery is full charge b4 the up date
if ur phone wen u charge seem to no charge actioly is charging!
give a try
2 things, first bad battery, sometimes bad battery works for few minutes then your phone just dies on you, it says its fully charged but it aint. That red light flashing only means that your phone has LOW BATTERY. 2nd your phone software has problem. If you have another ericsson that uses the same battery you can check it the battery is ok, its the only way you can find out if the battery is good. If the battery is doing ok with another cellphone then your cellphone software has problem.
check starter solenoid.see if getting power to starter side when pressing button .if yes check if power to starter w/ test light when pressing button.if power there check starter,also motor, will it turn manually or is it seized.if no power to starter side of solenoid, jump across solenoid posts w/ a large screwdriver -motor will probaly turn over,w/ key on.if small wire to solenoid has power when pressing start,solenoid bad,if no power, wiring or start button bad.
