Televison & Video Logo
El Dundo Posted on Jan 23, 2017
Hello, I have a hitachi tv mod#LE55A6R9A has sound no picture, I replaced the t con board same problem. What do I replace next?
Hitachi LE55A6R9A picture out but sound works. Menu there with flash light test. No lights in back when rear panel is removed. Which should I replace? Power Supply Board? Main Board? T-Con Board?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Hitachi LE55A6R9A has sound but no picture. Passes flashlight test. No LED backlights appear visible at all. Trying to determine whether to start replacing boards or LED strips first.
The led driver may be on the main board or on it's own board. Led strips don't fail all at once so if you had a dark area of the picture then I'd suspect a led strip. TV Parts Universal TV Stands DLP Chips ShopJimmy This is the place to get parts.
Any way to test a Hitachi LE55A6R9A to find why no sound or picture?
First, test fuse if there is one. Second check high voltage near 390 to 400 DC volts at the capacitor. Hopefully, there is only one capacitor.. The high voltage circuit is near where the AC 120 volts plug enters the TV. So, without high voltage, TVs are shutdown. Today's TVs are like computers, sensors on the circuit boards, feed back to a "CPU".
Sound but no image on Hitachi 42pd5000
Two things need to be checked. The ballast board and the T-con board. Shine a flashlight on the screen with the TV on...If you see a faint picture moving, then the T-Con board is OK. The ballast board for the white backlight is bad. If you don't see a faint picture, then the T-con board is bad. You can get parts here: www.shopjimmy.com TV Parts Universal TV Stands DLP Chips ShopJimmy
Hitachi le55a6r9a has audio but no picture. When you shine a flashlight on the scree, you can see a dark image. Which piece needs to be replaced?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Hitachi TV 55inch LE55A6R9A doesn't have picture or audio but has power.
Main digital board fault. Check and replace it. If you wish to get more details visit the site linked here. http://electronicshelponline.blogspot.com/
I need to know where to locate the back light inverter for a Hitachi LE55a6r9a hdtv.
2answers
I have a Samsung TV model UN50H6350AFXZA which has sound but no picture. Backlights work. Replaced t-con board with new one, but not fixed. What next?
Main board. T con board is only involved with video issues. Main board goes both ways and since you already replaced the T con board that is your only alternative. U got backlite so inverter board is good.
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
