Sharp LC-60LE640U 60 Inch 1080p 120Hz LED HDTV Logo
Raymond Posted on Dec 03, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Sharp lc-60le640u Tv won't turn on, and the power icon start to do 1 long flash and 1short flash. Can anyone explain what is going on with my Tv? And how do I repair it?
Eddy Kinuthia
Level 3:
Master:
  • Master 235 Answers
  • Posted on Dec 06, 2016
Eddy Kinuthia
Master
Level 3:
Master:
Answers
235
Questions
0
Helped
49021
Points
1252
This is a typical power problem. Have a qualified technician check the power board or buy a new one and replace.
My sharp tv model LC-60le640u don't come on just have a white blinking light on the bottom
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
2answers
Sharp LC 60LE640U will not turn on power light just blinks
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
1helpful
TV wont start up, blue power icon flashes 3 long and 1 short flash repeatedly
You need to reboot the tv. you've had a signal drop which locks up the tv. call sharp techicon1.png support and they will talk you through a reboot.
The white arrow on the bottom of the screen is flashing and no picture will come up on the screen
Can you see the "Menu" display using remote/direct switch on tv. If yes, check your input and selection. Else consult local service.
Sharp Aquos LC-60E79U has flashing green power light and OPC light but won't turn on
Try to I unpluged the power, push volume and channel down, pluged power again
While it's flashing unplug your TV from the main power source for 15 seconds,Then press Valume Up and Channel Up, while holding it plug the TV back in, you should see the TV Turn on. How to Reset Your Sharp LCD TV TV Repair
My tv shuts off than the power light flashes
You may need to buy a new lamp (bulb) for your TV. We didn't know what was going on with our Sony WEGA when it just shut off and the power light flashed. The next day we heard two different "pops" and the picture died. Did a Google search, found a new lamp, and installed it. Works fine now. Good luck!
1helpful
Tv will not turn on
Flashing standby light indicates something wrong with internal circuits. The number of flashes must be counted ; at one time switch ON. These are called blinking codes. For the number of these blinks, you can get an idea about the faulty section circuit inside it. Just count it, and visit this site for more details. Blinking codes to many brand TVs are given in detail. Pull up older posts there. Look for blinking codes to Sharp brand TVs. Search the site with patience.
1helpful
Go to turn on tv and all I get is flashing red light and tv won't turn on. Was working the other day.what do I check?Sharp LC-26GA5U
Try unplugging the TV from the power point and leave unplugged for 5 min.
Or the batteries in the remote may be flat, try replacing the batteries.
If this doesn't work the TV may have a fault.
I hope this helps
MobileJB
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Grand Canyon Tech
Grand Canyon Tech
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
