Cars & Trucks Logo
i
ian mciver Posted on Nov 27, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Plastic roller under seat support to allow movement avanti is400
SeabeeMechanic
Level 3:
  • Seat Master 1,367 Answers
  • Posted on Nov 27, 2016
 SeabeeMechanic
Seat Master
Level 3:
Answers
1367
Questions
Helped
412658
Points
3754
What is your question ? Adding more specific detail information about your vehicle would also help. Like, year, make and model
1helpful
2answers
2006 cadillac srx Heat doesnt get hot on drivers side. Is this controllled by a fuse?
There is an electric motor that controls the blend door. You probably have an issue at the blend door. Either the motor is bad, or the actuator isn't connected. The actuator arms are know to crack and allow the motor to move without moving the actuator.
tip
How to Replace Door Locks in Avanti convertible ?
The procedure to replace the door locks in car is as follows:--
1) First of all carefully remove the arm rest and any speaker covers if speakers are connected.
2) Then remove the door panel. The door panel is connected by plastic clips.
3) Then remove the door handle screws with the help of screwdriver.
4) After the screws are removed the door handle will come out
5) Now the interior doors handle needs to be removed. the interior door handle is fitted by plastic clips you can use a pliers to pop out the plastic clip, then twist the clip to allow the interior door handle to swing free and easily come out.
6) Take the door handle out
7) Now in the door remove the rod from lock core.Then remove the two bolts holding the door handle assembly.
8) Now before removing the old door lock, please take note of the position in which it is placed. So while inserting new lock there is no problem about placing the new lock.
9) Insert the new lock carefully to the proper position. And reverse/refit all the parts which you removed while replacing the old door lock.
This will help. Thanks.
Crossfire power seat has erratic movement
Test the switch your using, to perform
the seat movement with the issue
Check for items under the seat,lack of lube,
loose wire connections,especially the drivers seat
Power driver seat will not fully move forward or backward.
make sure nothing is lodged under the tracks this is common things get thrown under the seat and stops them in the track
Have a 2005 Dodge magnum and the driver side seat will only move up on the right side while the left side just stays in place
Either the seat track is broken or there is something jammed up under the seat that will not allow proper movement of the seat - or both. Take a look under the seat to see what is going on.
3helpful
3answers
Driver's side front seat will not recline
first check the switch,motor is OK since other movements are OK. also find out the welds they use under the seat to connect the steel brackets are not that strong and snap leaving the seat at an angle position.The best bet is to look under the seat at the side thats angled down and look for a long metal pipe with a U shape it might look a little rusted.If this is so you need to find a welder to reweld the two pieces.
My muffler system has got louder under the drivers seat side.What would you recommend me replace?
there are a few things possible a flex pipe (piece the allows slight movement ) or a gasket fairly cheap worst case $100-150 at a repair shop, less if you want to get dirty on your own car. parts stores have what you need
6helpful
My power driver's seat 1999 lincoln continental keeps returning to the full back position even when i drive.I changed the entire seat frame with new motors and gears, $500.00 no fix. I have to pull the #39...
does this have automatic seat positioning when you open the door or hit the unlock button on your key fob?
here's how it works:
Seats — Programmable
The memory seat system allows automatic positioning of the driver seat to two programmable positions using the message center, the key fob or the keypad on the door.
Seats — Driver Seat Module
The Driver Seat Module (DSM) is located under the driver's seat and is attached to the seat frame. The DSM will:
  • control the movements of the driver's seat and power exterior rearview mirrors
  • store and recall seat and mirror positions of two personalized settings
  • receive all power seat and mirror control inputs from the Driver's Door Module (DDM) through the J1850 communication network
  • move the exterior rearview mirrors downward when the transmission is shifted into reverse, if enabled.
Seats — Driver Door Module
The driver's seat regulator control switch is connected to the Driver Door Module (DDM). The DDM receives the driver's seat regulator control switch input and communicates the direction of movement over the J1850 communication network.
Visual Inspection Chart Mechanical Electrical
  • Front seat tracks obstructed.
  • Seat at limit(s) of travel.
  • Open fuse junction panel Fuses 39 (10A), 41 (20A), and 28 (10A).
  • Open power distribution box Fuse 13 (30A).
  • Loose, corroded or damaged connectors.
  • Damaged switches.
  • Damaged motors
Also, the dealer can run a scan on your seat modules with his tester and tell you what the codes are. They should only charge an hour to do this. Then you can decide what to do. Call your dealer and ask how much to run the scan test.
2helpful
Third row seats
A little plastic bumper, located on a metal tab on the inside of the bottom seat cushions breaks off. It is supposed to hit the seat back release and allow the back to fold down when you push the bottom cusion in all the way. I finally just bent the metal tab up so it would hit the release and that fixed it. (Look for the broken palstic pieces under the seat cusion area as an indication) The dealer replaced the plastic part several times... a waste of time.
Top Seat Experts
vince
Steve Sweetleaf
Steve Sweetleaf
Jose Ramirez
Are you a Seat Expert? Answer questions, earn points and help others
