I have problem with my MFP 1522nf Printer I cant recieve fax on incomming call it is quite dead while It is set in automatillay answer mode when I dial it dial and gives tone but while in comming call no rings no reply ring answer mode is 1 but quite I checked every way settings wires but cant understand can any one know about this and help me.
The problem could be with your phone service if you are on digital lines, you would have to install a digital to analog filter. If you are analog the comm errors are typical of a line with a lot of static. You can change two settings on the printer which should solve the issue until you install a filter.
The two settings which are under the fax set up menu/ all faxes\ Error correction mode (ECM) set it to off Fax Speed set it to medium.
Yes you can send fax from computer.You need one dialup connection with Fax modem. then you need fax software. there are many software availble on the net . One is Mighty Fax. you can download it from the internet and many other you can search in google.
