Pride Mobility Products New Pride Mobility Jet 3 Ultra Power Wheel Chair Logo
Angie Daughtry Highsmith Posted on Nov 03, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bought new batteries for jet ultra 3 all lights work (red, yellow, green)but joy stick does nothing. What could be wrong?
Horn works, speed buttons work.
Marvin
Level 3:
Top Expert:
  • Pride Mobili... Master 85,242 Answers
  • Posted on Nov 03, 2016
Marvin
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29061120
Points
266281
Most likely the joy stick and the circuit it controls is defective.
Jet 3 Ultra kicking error code 3 red, 4 yellow, 1 green.
check connections to controller, may have damage.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
How to reset manual brake control and where is it.lights go on( 2 red & 2 green) but jet joy stick is so touchy lights blink and I have to restart it.
If the joystick turns completely off when you try to drive it means the batteries instantly are dropping voltage below the operating capabilities. I have also seen bad connections in the battery wiring harness cause the same thing.
Jet 3 ultra power chair won't move
Move the freewheel levers back and forth so the chair does not move drive position
I have a blue jet 3 ultra n i just put 2 new batterys on it and all it will do is flash a red light in the top left corner of the battery light on the joy stick and the horn works but will not move what...
Check your battery wiring on the Jet the wires from the circuit breaker need to connect the positive of the front battery to the negative of the rear battery and the other wires connected to the positive of the rear battery and negative of the front battery putting the batteries in series to generate 24+ volts. If you have a voltmeter before you check the wiring set it to 200 volts dc and plug the leads into the 2 outter holes of the charger port located under the front of the joystick. If your batteries are wired correctly you should be reading 27+ volts without the charger plugged in and your batteries fully charged. If you are only reading 12 volts then the wiring is wrong and needs to be fixed. Leaving the voltmeter in the charger port plug in your charger and you should be reading 27 -30+ volts at the charger port anything less than 24 volts indicates your charger is not charging Hope this helps
On off switch lights the red yellow green readings at full strength but continues to just blink when turned on.. get no response trying to use the joy stick. - the seat riser and speed buttons show no...
YY count the number of flashes ie 4 flashes pause 4 flashes pause. This will give you the error code and will tell what is wrong with your chair Check out my tip on Flash codes if you can't find them in your manual. Without fixing the problem that generated the flashing you won't be able to use the chair until the problem is fixed. If you want you could contact the provider that sold you the chair and have them troubleshoot the problem for you Hope this helps
No power to motors joy stick does not woirk
Hi. If you count how many lights were flashing and let us know then I can look up that fault code and tell you what it is. Do you have the free-wheel levers in the correct place? Check the motor and battery connectors. How old is the machine, are the motors or brakes faulty. The machine will not operate if the charger is still connected. Good luck. Neil.
Will not turn on after charging
Sounds like it's time for new batteries.
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
