All the other plug in wires are in the same location and have the same color code, except two of them. They are next to each other. On the old board the white plug is on the top with a red plug below it. The wire harness plugs do not match as well. can I attach the wires per plug color and orientation? I plugged the wires into the new board with the correct color match on the sockets. I made sure that the plug in terminals were plugged in with the one way plug in to match the new board. I had to file off the protruding ridges that align the plug in to the sockets. The dishwasher now works. So people that have the same problem with a bad PCB Assembly Main board 6871dd1006f(r) can replace it with the new 6871dd1006t. It shows that the original board has been discontinued. So my problem has been solved.
SOURCE: New World DW60 dishwasher not
I f you have warranty on this please call them, you have a defective D/W.Unless there is no charge for repairs ,don't spend a dollar on what is going to be a on going problem ahead.To explain how to fix this is what the manufacturer should have done in the factory and not made 1 dollar off of this defective D/W until it proved this to be ready .What has happened to Quality Control ? Does it no longer matter ? Very sorry ,you should seek a refund ASAP.
SOURCE: ERROR CODE "LE " ON LG DISWASHER
You should check for that the pump motor turn freely. You will have to remove the sump cover in the bottom of the dishwasher and manually turn the pump impeller. (note: screw holding the impeller on the motor shaft is a left hand thread) There may be an object there or at the cutting blade a bit lower down that is preventing the motor from turning. Motor should turn easily, smoothly, and quietly. There have been issues with magnets in the motor windings cracking, resulting in hard to turn or noisy motors. Also, models produced with serial numbers 501KW_____ to 702KW_____ may have wiring which has become embedded in the door insulation material, softening the wiring insulation, and causing a short to the motor. The fix for that is to replace the wiring harness and outer door liner with one with a different type of insulation. (not much fun to do)
SOURCE: Error code LE shown on
Hello JA12345,
Here is a link to the service manual for your dishwasher. Page 25 discusses the error code...
http://136.166.4.200/contents/Dishwasher/LDS5811/LDS5811_Service_Manual.pdf
Hope that helps you resolve your problem..
Regards,
Rick
SOURCE: Frigidare Gallery Pro Dishwasher Control Panel Power
It can be the problem with the transformer. Try replacing it with another one.
SOURCE: I have a LG LDF6810ST dishwasher with a tE error
Follow up to previous post.I replaced my sum seal and other nec. gaskets and reassembled.The TE code is gone and dishwasher performs as designed.I hope this helps someone with one of these POS dishwashers.Thanks
Hi
First make sure that nothing is blocking the drain pump
assembly located inside the lower front panel of the dishwasher. If the issue
returns after its cleaned then try to reset the dishwasher control by pressing
the HEATED DRY button and hold it for 15 seconds, if its still not resolved
then it means that the control board has gone bad and should be replaced. Hope
this helps...please post back for further assistance.
Daniel
