You have a short somewhere in the speaker wires.
Like where? Its all brand new wire? Today i took the amp to my buddies house just to see if the amp was bad or to just see if it worked with his set-up and she played like a charm......i go to put it back in my pickup and she goes right back to protection mode..........im so lost......have had professional installer look at it yesterday and he said the amp was bad........im like 12 hrs into testing and checking again and the trouble shooting bit im running out of the easyones to try.......
SOURCE: sub will drain all the sound off the front speakers
if you have both amps connected to the same power wire this will happen...run another power wire to the alpine and this should solve the problem.
SOURCE: my amp keeps going into protect
if your amp is a 2 channel you might be using the left positive and right negative or vise-versa. check and make sure your only using right or left and not both, as it will cause your amp to go into protect
SOURCE: my mtx 502 was going into protection mode, but now
http://www.retrevo.com/support/MTX-502-Car-Amplifiers-manual/id/23108bh332/t/2/
service manual for troubleshooting
www.caraudiohelp.com/newsletter/amp_protection_mode.htm -
http://www.bcae1.com/repairbasicsforbcae1/troubleshootingbasicsampinprotect.htm
Above, is how to troubleshoot, protection problems.
