U1040
DTC U1001-U1254 IPC, PCM, SDM
Electronic Brake Control Module (EBCM)
040
The control module ID number list below provides a method for determining which module is not communicating. A module with a class 2 serial data circuit malfunction or which loses power during the current ignition cycle will have a Loss of Communication DTC set by other modules that depend on information from that failed module. The modules that can communicate will set a DTC indicating the module that cannot communicate. When no message is detected from a learned identification number for 5 seconds, a DTC U1??? where ??? is equal to the 3-digit identification number is set.
Control Module
ID Number
Powertrain Control Module (PCM)
016
040
Dash Integration Module (DIM)
064
HVAC Control Module or IPM
065
Rear Integration Module (RIM)
066
Inflatable Restraint Sensing and Diagnostic Module (SDM)
088
Instrument Panel Cluster (IPC)
096
Head Up Display (HUD)
098
Radio
128
Remote Playback Device - CD Changer
130
Digital Radio Receiver (DRR)
137
Vehicle Communication Interface Module (VCIM)
151
Driver Door Module (DDM)
160
Front Passenger Door Module (FPDM)
161
Left Rear Door Module (LRDM)
162
Right Rear Door Module (RRDM)
163
Memory seat Module (MSM)
166
Driver Door Switch Assembly (DDSA)
170
Remote Control Door Lock Receiver (RCDLR)
176
Theft Deterrent Control Module
192
The electronic brake control module is communicating , no need to bother the PCM . The code was set in pcm because it lost communication with EBCM , PCM not the problem .
Left Front lower corner of the engine compartment, under the air cleaner housing .
Check power's an ground's . Will a scan tool talk to it ?
The Powertrain Control Module (PCM) is located on the left front frame rail.
4.2L Engine
The Powertrain Control Module (PCM) is located in the engine compartment. It is mounted on the left side of the engine.
