Vizio 37" vx37l hdtv widescreen lcd/tv black/silver - b Logo
A
Anonymous Posted on Sep 29, 2016
Vx37l blue screen
How do i fix blue screen
Level 3:
Top Expert:
  • Vizio Master 76,851 Answers
  • Posted on Sep 29, 2016
Vizio Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15008792
Points
237762
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
1helpful
How do I fix my Vizio Model VX37L HDTV10A distorted colors
its time for another Tv set man
the screen gone bad
My vx37l powers on get a blue screen then shuts down
Displays blue screen and shut down; denotes no signal input to TV. Check all the signal inputs, Ariel, AV or so. If all are found OK, the tuner to this TV is faulty. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Vizio vx37l hdtv10a
If recently bought, take it back as a default.good luck..
Vizio 37 hdtv problem, blue screen w/ no signal displayed then shuts down in about 20 seconds
The problem is the main digital board. It does not have a reset button.
I have a vizio vx37L that powered on for about 5 10 min then went to a black screen but I could still hear sound. When I unhook the Direct tv it has balck screen still and no sound screen flicks when you...
Ur LCD inverter board is dead.Replaced this LCD inverter board will get ur picture back.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.The board is a long shape board.
21helpful
2answers
Have a Vizio VX37L that when it is turned the
HERE'S THE FIX: I just went through this with my Vizio VX37L. TV is stuck in RGB input. This is the fix.... TV is stuck in RGB input.
(option 1) Power on TV, and press the INPUT button repeatedly and rapidly until you can change to a different input, such as AV.
If that doesn't work, try:
(option 2) With the TV off, press and hold the INPUT button on the side of the TV for about 5 seconds. The TV should power on and the input list will appear. The TV will no longer be locked, and the INPUT button should function properly after that.
Option 2 worked for me!
Our Visio VX37L comes on with blue screen and "no signal" at top of screen, then turns off in about 5 seconds. Does not respond to any of the other buttons such as "input". Once off then will not come back...
Television was repaired under warranty. A new motherboard was installed but did not fix the problem. A new front panel assembly was installed and fixed the problem.
1helpful
Vizio has no power want to check fuse
remove back, only exposed board there is PS, look where blue/brown AC wire plugs into it, fuse (F1) is there (5amp-250v)
if fuse is good and you get no power or front light replace that board, or start component level troubleshooting (usually regulator trans or SM fuses (000)
Orange screen colors different
orange on vizio is not working
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
