You would have to subscribe to that feature from your local phone company, then when a number like that calls they will get a recording that states you do not accept blocked calls...
You can't. When caller-ID shows "Private", it means that the caller does not want you to know what number they are calling from. (Tip: These are good messages to let the answering machine answer. If they want you to call back, they'll have to leave a number.)
Just dial *67 before the phone number on your cell phone. This code is the universal command to deactivate caller ID.
For example, placing a blocked call would look like*67 555 555 5555 (without the spaces). On the receiving end, caller ID will usually display "private number" because it has been blocked.
Though you won't hear or see a confirmation of a successful caller ID block, it will work.
Telephone settings Select Menu > Tools > Settings > Phone. Select from the following: • Call — Define general call settings.
Call settings To display your phone number to the person you are calling, select Call > Send my caller ID > Yes. To let the network determine whether your caller ID is sent, select Set by network.
Thanks for using FixYa. I think you have stored more than 100 Caller ID messages and hence the caller ID is not showing on Uniden Tru8888.In the following cases the caller ID will not be shown-
If you answer a call before the Caller ID message is received (for example, before the second ring), the Caller ID message will not appear.
When the call is received via a telephone company that does not offer Caller ID service, the caller’s phone number and name does not appear. (This includes some international calls.)
When the call is via a private branch exchange (PBX), the caller's phone number and name may not appear.
You may receive any one of the following messages:
When a private name is received; Private Name
When a private number is received; Private Number
When a unknown name is received; Unknown Name
When a unknown number is received; Unknown Number
When invalid data is received; Incomplete Data
The Caller ID list stores information for incoming calls - even unanswered calls. You can store up to 100 Caller ID messages and phonebook entries (including Speed Dials) for each handset and the base. You can view the Caller ID list through the handset or base during a call or when the phone is in standby mode.
Memory locations for Caller ID messages and Phonebook entries (including Speed Dials) are common, you can store up to all 100 entries for each handset and the base. Caller ID messages are not stored when you have 100 phonebook entries. When you have stored a total of 100 phonebook entries and Caller ID messages, the oldest Caller ID message is overwritten.
Please do rate the solution and revert for further assistance.
The caller is using private number. If you wanna know who's calling you, turn off your phone. If the caller always call you all the time, you'll be lucky. Because there will voice message received from the operator and you are able to know the number who's calling you.
You can do that also by typing "#31#(destination no.)" then call.
If you have a private number or unlisted number, you must dial *67 before dialing the number. This is only needed if the number you are calling rejects blocked/private numbers.
If you answer the call, the number (or number and name) stays on the display until either you or the caller hangs up.
If
you do not answer the call, most display units keep a record of the
calls received, including the phone number (or number and name), date,
and time.
If the letter P, priv, private, or a similar term appears, the caller may have blocked the display of his or her number.
If the letter O, ????, out of area,
or a similar message appears, the caller either is in an area that does
not support Caller ID or has placed the call using operator assistance.
Caller
ID comes with Anonymous Call Rejection, which, when active, allows you
to reject calls from callers who block their number. Your phone does
not ring, and the caller hears a message saying blocked calls will not
go through.
To turn on Anonymous Call Rejection, press
*77 on a touch-tone phone (or dial 1177 on a rotary phone)
To turn off this service, press
*87 on a touch-tone phone (or dial 1187 on a rotary phone)
or go through http://www.decommunications.com/support/topics/repairs/phone/no-id-name.php
