Need wiring help
SOURCE: PTC relay on compressor
Try to find the "secret" wiring diagram. Almost all refrigerators have a hidden paper wiring diagram. It is usually tucked into a slot under the refrig, behind the front grill, or otherwise on the inside of the lower rear cardboard fan cover, or sometimes inside the back area near the fan. While you're in there, it's a good practice to clean the coils.
SOURCE: Wiring diagram needed RV rooftop coleman
Motor1258,
Thanks for the response, to be more specific, the nine pin connector was damaged, but I was able to connect the wires back to main unit panel. I am ready to hook to the hunter thermostat and do not know which wires to connect to. This is my problem and I do not want to short something out. Hope this helps, I want to get it installed again. Thanks again for caring....Jerry
SOURCE: kia optima 2004 transmission selector wiring colour diagram
Try this website www.kiatechinfo.com
This will be far more usefull than me just handing you the diagram
SOURCE: wiring is broke on 4 pin mike plug
This is the wiring for a stock mic ... if it is a different one let me know
Mic Wiring
Stock
1- Shield
2- Audio
3- Transmit
4- Receive
