20 Most Recent
Eagle Cuda 242 Fishfinder Questions & Answers
When I turn on my Eagle Cuda 300, it goes straight
Try this, hard reset-FYI-This will delete saved data
1. Turn unit OFF-Press and hold the UP arrown key
2. Press power, unit will enter production keyboard test mode
3. Release the buttons
4. Press PWR/CLEAR key 7 times. (SYSTEM INFO SCREEN)
5. Press MENU/DOWN and unit will shut off
Hope this helps
Need pin outs for eagle cuda 168
Coda has flat D 6 pin with center pin grd for 4 wire vs old arrow 6 pin round black one.
Flat on bottom, count cw 12345 pins w pin 6 center... 2 pin minus 12 v, 4 pin +12v.
For other 4 wire like speed/temp... 1 blue, 3(top) white, 5 pin bot right yellow, 6 center ground for spd/temp.
White for speed wheel, rest not known.
I used 2wire cable and 4wire cable with 2ft pigtails and 3amp fuse in red wire.
I used old radio stereo 2 and 4 pin male female connectors at end of pigtails.
Looking for manual
Dear Geraldnappy,
Check this link for the manual you are looking for!
http://www.retrevo.com/support/Eagle-242-manual/id/517ag923/t/2/
With kind regards,
MisterN
How do i seal the
You want to use a special BELOW THE WATERLINE sealer, you get from a marine supplier. This material takes DAYS to cure, so crank that in to your plans.
