20 Most Recent Dometic 3313192.000 White Single Zone LCD Thermostat Heat/Cool/Fan Questions & Answers
not seeing 2nd ac unit check dip switches
Dometic... | Answered on Oct 06, 2017
Same problem...then discovered my thermostat was set to Celsius instead of Ferinheight... pressed toe temp up and temp down buttons to change..fixed...
Dometic... | Answered on Aug 03, 2017
I'm pretty sure this thermostat uses digital communications with a dometic control board. In other words, there are no contacts in the digital thermostat to turn something on and off. Even if you ran a 12VDC wire to the thermostat for power, it won't work to replace a "real" thermostat. I bought one to replace my old analog thermostat and it's not going to work for me.
Dometic... | Answered on Dec 02, 2016
http://www.campingworld.com/includes/productSpecs/Single%20Zone%20LCD%20Operation%20Manual_3313327.037.pdf
This is the manual I found and it says on page 11 that the unit is not communicating with the furnace .
Dometic... | Answered on Nov 13, 2015
unplug cable at both ends. remove cover from t-stat. using contact cleaner spray contacts on cable and points it connects to. if necessary replace t-stat and cable
Dometic... | Answered on Aug 20, 2015
check breaker and fuse it will be seperate from 1st a/c
Dometic... | Answered on Aug 19, 2015
the heat and cool use the same fan. if compressor is running with heat then you have relay issue
Dometic... | Answered on Aug 18, 2015
thermostat, relay module,heat strip, fusible link.
bad thermostat or relay stuck in.
Dometic... | Answered on Aug 17, 2015
Indoor coil temp defective. Replace it.
Dometic... | Answered on Jul 16, 2014
Error Code:
E1 Loss of communication between the Single Zone LCD thermostat and the mod-ule board. LCD will cycle between E1 and the previous mode setting. System
will shut down.
E2 Open circuit or out of range Indoor Temperature Sensor. Heating and cooling
operation will be locked out. Fan operation can continue to operate.
E3 Shorted Indoor Temperature Sensor. Heating and cooling operation will be
E4 Open circuit or out of range Outdoor Temperature Sensor (select models). Heat
Pump operation will be locked out. Air Conditioner, Fan and Furnace operation
E5 Open circuit or out of range Freeze Sensor. Air conditioner mode of operation
will be locked out. Furnace, heat strip, heat pump and fan mode of operation can
continue to operate but displays the last temperature set-poi
Dometic... | Answered on Jan 28, 2013
Dometic 3313192.000 White Single Zone LCD Thermostat Heat/Cool/Fan Logo
17 questions posted
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
Thomas F. Schneider
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Dometic Heating & Cooling
Most Popular Question
dometic digital thermostat wont go up
  • Heating & Cooling
