DECT 3135
SOURCE: Will Uniden 2085 DECT phone work in india
Caller ID standards are different in India,so caller id won't display ; need to buy a converter which converts from DTMF to BellFSK standard
SOURCE: my cordless phone says
With the phone in standby, press MENU/SELECT on the base.
Move the cursor to select the Register Handset menu, and then press MENU/SELECT. Handset Registering will appear.
On the handset, press and hold # until the handset beeps and displays Handset Registering.
When the handset has registered to the base, the LCD will display Registration Complete then show the handset ID number.
If the display shows Registration failed, repeat the process again.
Note: If a handset has ever been registered to a base, reset the handset before you register it to a new base
SOURCE: UNIDEN DECT 6.0
DECT 6.0 is not a model number, it's the generic name for the cordless phone technology in use. So I can't give you a more specific link than this one, which takes you to Uniden's download page for manuals. Pick your model from the list, and the manual will explain the steps you'll need to follow. Your phone's model number is on a sticker normally found on the rear or bottom of the base unit.
Testimonial: "thank you very mucy "
SOURCE: how to take silent mode
To turn off silent mode, press the "#" and hold down until it changes. :)
SOURCE: how do you turn off silent mode on Uniden DECT 6.0
In standby mode pressing and holding # brings up the "Silent Mode" special feature .. unfortunately the only options are to set the time for the device to be in silent mode and no way to turn if off. The solution is supposedly to press the # key again and hold it down, but this does not work either. The only way I can manually return to not be in "Silent Mode" is to reset the base unit!!
