Popping sounds from plasma tv's are almost always caused by a blown sustain board ( Y,Z, or both). It could be a main power supply also. Have a technician check it out.
The fuse blown because theres a short circuit connection in the PCB power supply of your television.Please check the power supply inside,remove the back cover to see the power supply section.unplug first to avoid electric shock.Will you check the bridge type diode first.If the bridge type diode or diodes is shorted the fuse is always blown.Using digital tester check diodes,regulator transistor,and other transistor around the power supply.
Hi
Its means that your television have no power.Maybe the power supply is dead.Its better to repair the power supply.If you have knowledge in TV,will you remove the back cover and check the power supply.Check the fuse if blown and check if the capacitors is leaked.
this one has a few bad caps in the power supply,C5 and C6 330mf at 450volt and Q6,Q8 are problably bad part number K2372,you mite want to replace the power supply board part number BN96-00249A
