I have a Bosch Classixx slimline dishwasher. I completes most of the cylcle but trips out the electricsnear the end of the cycle - probably the drying cycle - any ideas Garry
Hello Garry,
I suspect the element in the water heater is either burning out or shorting to earth. If it's burning out, the increased resistance will cause an overload and trip the breaker or blow the fuse for that circuit. If it's shorting to earth, it may trip both the breaker and the RCD in your fuse box / consumer unit.
Next time it happens, check whether the RCD switch (assuming you have one) is in the 'OFF' position. Most breaker boxes will be fitted with an RCD which protects many, or all, of the individual circuits. It's easily identified by the presence of a 'TEST' button.
That's only going to be a clue to the likely cause of the fault though. You really need to do some testing of the element with an ammeter and/or multi-meter, if you have one. I can provide instructions for testing if you have the equipment and inclination.
Unfortunately, if it is the water heater, the cost of a replacement is about £100 for the part alone, for the SGS43C12. Water heaters for most other Bosch models are roughly the same price and some of the older models can be £130+. If you need to get someone in to fit it, you could be looking at a total bill of between £150-200. Considering the age of the SGS43C12 / Classixx, it may be time to consider replacing the dishwasher.
Obviously, I'm assuming it's the water heater as this is the most likely cause, but there are other possible faults. If you need any instructions on testing, etc, please confirm the correct model number as the SGS43C12 isn't a slimline model.
Hope this helps. Please let me know if I can be of further assistance.
Regards,
BElectric
