For incoming calls, phone rings once, then shuts off. incoming Caller just hears a dead line. Outgoing calls are fine.
SOURCE: INCOMING CALLS
Not sure it this is a solution for ALL your problems, but...
I had a similar issue: Phone rings, caller ID info displays then seems to hesitate, then displays only "INCOMING CALL."
The issue seemed to be caused by interference with other devices on the same line (in my case, an alarm system).
Tech support had me change a setting on my TRU9466 base unit (this is one of the PowerMax 5.8ghz models). This is how we did it step-by-step on the base unit:
MENU
GLOBAL SETUP
IN-USE LINE SETUP
select LINE 1
switch to TYPE B
This seems to have solved the Caller ID "interference" issue -- my Caller ID now displays as it should. The Tech Support person suggested trying that TYPE A/TYPE B setting on "OFF" if TYPE B didn't solve the problem, but thankfully, it did.
Now Cheryl, it sounds like your issue is more involved than this -- I didn't have any connection problems -- but perhaps they're related -- you might try my solution.
SOURCE: uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
SOURCE: Disconnects incoming calls after one ring
The problem may be a short on your line. (Have the local Teleco check your line.) If you have other phones, you may want to check them for dial tone(DT) when this happens. If you have no DT, your cordless may be the problem...unplug, and let charge overnight. If problem continues, replace the battery in cordless, or discontinue use.
SOURCE: one ring - noise like fax to caller, phantom call to receiver
Try unplugging all sets and call in. Do you still have a faxlike tone, like from an ALARM system or something else down the street?
SOURCE: I can make and receive calls, but I cannot hear anything.
Check Windows Sound mixer for application volume. Down in system tray at right side of taskbar double click sound icon for XP or click sound icon once and click Mixer for Vista. Look through volume settings for your phone application. Make sure it is not muted and volume is up.
