SOURCE: insert correct sim card
i you should try a software update, you can get this from www.sonyericsson.com/support. hope this helps
SOURCE: Sony Ericsson D750i SIM card transfer
From the main menu, Choose contacts
Select options and Press Advanced
Choose "Copy to SIM".
Select one of the options that pop up.
All the existing SIM card data is replaced when copying the contacts from the Phone to the SIM card.
Pictures and text message can't be saved to sim-card.
You need to transfer these with memory card or to computer and from computer to other phone.
Succes
SOURCE: I am trying to copy my contacts from my Sony
When in the phone book:
Press the menu button (far left) > More > Back up contacts > SIM card
SOURCE: how do i copy contacts from my sony ericsson
Hi Barbara.
It's actually fairly simple to copy contacts on the x10.
Just access you phone dial pad via your menu
tap "Contacts" above the number pad
Press the bottom Left button (The real button at the bottom of the screen)
Should now pop a menu up with the option to copy contacts.
If not then tap the "More" option and it will be in there.
Now you have the option of copying them to the sim card or memory card.
Tap the relative option. :)
SOURCE: sony ericsson xperia mini pro
There's an app you can download from android market called contact2sim which will let you do this.
