Http://cdn.powerequipment.honda.com/pe/pdf/manuals/31ZT7601.pdf There isn't a rotor or distributor on this engine. The ignition module can go bad. The flywheel of the engine has a magnet embedded in it to trigger a spark from the midule.
SOURCE: How to connect a Honda EU3000is Generator to run the home furnanc
In shor NO.....
1st item to buy if you must conect to your house is a change over switch.it HAS TO ISOLATE THE MAIN LINE TO THE HOUSE< OR YOU WILL KILL SOME ONE....the other thing you have to know is the house just a single phase or a multi.....to save you life and the lines man working on the line when you run your genset, get a contractor to do it....
SOURCE: i need to remove the gas tank from a honda generator eu3000is.
I have a ems 4500 honda, the gas tank looks like the upper bar needs to be removed to get the gas tank off, it does. Follow the
top bar down on each of the corners. Where the top bar meets with the bar below the gas tank, you will find a bolt in each of the tubes. Take these screws out, use a hammer to tap the top bar upward lightly at each corner. You should see the tubing sliding up out of the bottom tubes.
SOURCE: Honda EU3000is Generator is running poorly.
Can anyone help me with the eco-trottle switch when I switch it on it seems to run the same idle whether I have it off or on, what could be causing it not to work, is it a bad switch or I am running 89 octane could that be the problem.
Thanks
Alex
SOURCE: CONTACT BREAKER GAP FOR HONDA ES3500 GENERATOR
Recommended spark plug is BPR5ES (NGK) W16EPR-U(Denso)
Spark plug gap is 0.7-0.8mm (.028-.031in.)
Air Gap for your ignition coil is .4+-,02 mm(0.016+-0.008in.)
SOURCE: Honda EU30001 generator causes erratic pellet stove operation.
Ok Motors and the like generally DO NOT really go all that well from a generator, what load does the Stove use?, You must add up the cumlitive "Wattages" of ALL things connected, see your generator is about 3000 Watts, 3KW, How much "headroom" is there between the two? Whats supplied versus whats being used? Purely inductive loads, like Motors etc, are less responsive than electronic loads. I suspect that your generator is NOT providing enough current to the Stove, especially when "Other" things are connected. also. Look, if the, any, generator is 3000 Watts really you should only load it up to a couple of KW's, 2.5KW being about maximum. To do what you are doing would require, IMHO, at least, 5KW, to get the "Headroom" of current drawn over current able to be delivered by the generator. Also inductive loads loose heaps of power and actually cause a higher draw. So that your answer, you must use it well, inside it's rating, not right up to the limit.
The EU3000 series generators are inverter generators. The generator features an alternator, which produced high-voltage, multi-phase AC power. This power is converted to DC power and then converted back to AC. This process is controlled by a microprocessor and is necessary to provide stable, consistent power capable of running equipment sensitive to power surges. This type of generator provides higher fuel efficiency and lower operational noise ratings in a lighter model than home and work generators produced by Honda.
The Honda EU3000i Handi is a 3,000-watt inverter generator that features wheels, folding handle and a recessed convenience light. The engine is a Honda GX160, which features a 163-cc displacement. The AC output is 120 volts, with an average rating of 2,600 watts and a maximum production of 3,000 watts. There are three receptacles to include a 20A, 125-volt duplex and a 30A, 125-volt locking plug. The DC output is 12 volts and 100 watts. The EU3000i can hold 1.56 gallons of unleaded fuel, which will provide consumers with 3.6 hours of run time at 25 percent load for 7.7 hours.
