We have a Mabe stackable washer dryer that we've replaced the transmission and lid lock on. Green light flashes when it gets to Wash cycle or Rinse cycle. MCL1740PSBB02. It's a GE in USAWe have a Mabe stackable washer dryer that we've replaced the transmission and lid lock on. Green light flashes when it gets to Wash cycle or Rinse cycle. MCL1740PSBB02. It's a GE in USA
You can't post conmments that contain an email address.
A top-load washer tub is usually supported by four suspension rods. If one of the suspension rods becomes dislodged or breaks, the control board may stop the spin cycle several times to try to balance the clothes. Suspension rods will often come in a set of four and it is recommended to replace all four of the rods at the same time to reduce uneven wear.
Apr 16, 2012 - When the washer enters the spin cycle but does not start to spin, you will need to see if there is ... West Los Angeles Washer and Dryer Repair Service ....After the water has drained, the spin cycle will start. .... Drive Motor, GE, Maytagwashing machine won't spin, spin bearing, washing machine clutch worn ...
My washing machine will wash but the spin cycle will not spin or drain the tub what do I do to repair that? By Shelly H. ... Question: Washer Stops After It Fills for Rinse Cycle and Does Not Spin. By henryj ... Our GE washer will not spin when it has a load of clothes. It washes .... I have a Frigidaire stackable washer and dryer.
? 3:56
https://www.youtube.com/watch?v=_8myOfPzGfM
Aug 4, 2012 - Uploaded by Brad Hyman
My washer did not spin but the belt drive worked to agitate the ...How to Fix a Washing Machine That Does Not Spin (Fast and Easy) - Duration: 8:45. ... Washer Top Load Not Spinning - Repair & Diagnostic- GE, General ...Missing: dryers
If your washer will not agitate or spin take a look at this page GE Washer Not ... If the washer fills up with water then doesn't do anything at all and you do not hear ... if this were the problem, the water would not stop running, over-filling the tub.
Mar 12, 2005 - 10 posts - 3 authors
I have a GE "Spacemaker Laundry" (Stackable) model number ... Today it filled withwater initially then stopped working all together when it ... Bad motor, something jammed/seized up holding the motor back from running?
... this: Sensing led (Green) on, the lid locking led (Red) blinking with a clicking noise ... red led light goes off green led light stays on and the washer does not start.
Good Day, your machine is normal is washing cycle? if yes.do the same for
the fully automatic washing machine mostly have drain pump, please check the
filter of your drain pump, if clog your drain pump of some hair pins,cotton
buds or coins or any small item,that the cause of water stuck,and it will long
time draining or totally not running the drain pump.and its cause of stop of
cycle of washing machine in rinse time or spin time,because after washing the
pump must be on to remove water before start the next cycle.
3 year old GE stackable washing machine, had water coming out the top and would not drain or go through cycle, when shut off it drained a little but when turned on again it filled up and over flowed.
If the door lock light is on then is might be the "door lock enable spin switch" the plunger at the opposite end from the wax motor is not fully depressing the switch. In the stackable it is just behing the door lock. Remove the two middle covers (2 white phillips screws and one hex head screw on the middle of lower cover by the wires)to test place a few layers of masking tape on the end of the plunger and cycle the machine. Might also be a weak Wax motor (dark brown in color) to be safe replace both for about $12 each. Fix in 10 - 15 min.
Check the washer motor. Make sure that the motor is getting correct voltage and is working and spinning when you turn it on. It sounds like the motor is bad. You can remove the back cover to get to the motor to check it out
