The fridge is making an odd wheezing noise from the left rear. Does not go away when door open or closed. Does not sound to be a fan blade or motor. More like a check valve. I don't see any info on this. Any help?
Hi, no it's not constant. Lasts about 3-5 min from when I hear the noise again. Usually only hear it when it very quiet in the house. I will check to see if I increase the water pressure to the ice maker makes a difference. I have been thinking on the lines that lack of pressure may be causing a bleed down effect, causing air in the system. Thanks.
