20 Most Recent Samsung RS261MDWP - 26 cu. ft. Side by Side Refrigerator Questions & Answers
Very bad smell coming from my Samsung refrigerator
most refrigerators have a small drainage hole leading from the inside rear of the compartment to an overflow container behind the unit, pull the unit away from the wall and check if the liquid in the container has become stagnant, if so simply clean it out and run a small amount of bleach down the hole to disinfect the tube.hope this helps.
1/16/2018 7:52:40 PM • Samsung... • Answered on Jan 16, 2018
Samsung refrigerator loud noise
if the fan is still running when you open the door , the I would be leaving that idea as a last resort try this get 2 taper door chocks and put one either side at the back of the fridge push the cabinet sideways and slip one chock in a bit then do the other side many noises are from the bottom plate that the compressor is mounted on from tapping on the floor and lifting it a bit stops the noise the same as when you open the door the pressure on that plate is removed and so it stops hitting the floor
11/4/2015 3:31:03 AM • Samsung... • Answered on Nov 04, 2015
Water leaking on floor from clogged defrost drain line. How do we defrost the drain line so I can fix the drain hole. I'm trying to do fix like shown on YouTube.
The video is spot on for preventing ice from clogging the drain. To clear the ice from a frozen drain - you can either unplug the fridge and open the door and let it defrost without any additional effort on your part. or if you don's have a place to put the contents of the fridge, access the drain area as shown in the video. Get some dry towel handy for absorbing water. Fill a pot or pan with HOT tap water and draw the hot water into a turkey baster and then squirt the hot water down the frozen drain opening. Repeat as needed until you've melted the ice that has filled the tube - and mop up the excess water with the towels as needed.
5/14/2015 7:06:53 PM • Samsung... • Answered on May 14, 2015
I had a power outage and the control board is blinking 1 blue light on the freezer side.
Replace your bulb in your refrigerator
1/15/2015 10:31:30 AM • Samsung... • Answered on Jan 15, 2015
It dosn't cool
try unplugging and back in . or turn breaker off then on
8/31/2014 10:17:29 PM • Samsung... • Answered on Aug 31, 2014
0answers
0answers
0answers
0answers
Samsung RS261MDWP - 26 cu. ft. Side by Side Refrigerator Logo
29 questions posted
Top Samsung Freezers Experts
Jay Finke
Jay Finke
Arnie Burke
Arnie Burke
Are you a Samsung Freezer Expert? Answer questions, earn points and help others
View Most Popular
Samsung Freezers
  • Samsung Freezers
Most Popular Question
samsung refrigerator loud noise
  • Freezers
