Sony BRAVIA KDL-40S2000 40 in. LCD HDTV Logo
J
John barker Posted on May 26, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bulb takes long time to get bright but not bright enough
Level 3:
Top Expert:
  • Sony Master 76,851 Answers
  • Posted on May 27, 2016
Sony Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15007984
Points
237762
Check the voltage to its inverter board. If you wish to get some details; check the site linked here. Pull up older posts.
What is the maximum wattage bulb that you can put in the Langston 60" ceiling fan light kit? It comes with 2 - 13 watt CFL bulbs. They are not bright enough, so we would like to make it brighter.
Get new LED lamps with low wattage and high brightness values. Additionally, the LED bulbs last a long time and use far less electrical energy than standard bulbs.
Jan 16, 2018 • Dryers
1helpful
Odd problem with ceiling fan and LED
This is a common issue with LED bulbs in the application that you have it installed in, When you changed the socket it reset the unit. Most of those wont ever see an LED because the LED wont draw enough current. Then control box depends on a current draw in order to stay on. LEED bulbs don't have enough current draw.
Oct 12, 2017 • Dryers
While drivig my headlights get bright then dim
It sounds like a possible problem with you alternator not providing enough volts/amps to keep the lights steady. If it one light, it could be the bulb going out - buy a bulb from your local auto shop and try that. If it is both lights, you should have your alternator and battery checked at a Toyota dealer, local repair shop or if your handy with tools and don;t mind the work, pull them out yourself and take them to a local autoparts shop where they can test them for free. If either fail the test, replace them.
Headlight brightness not sufficient.
The actual replaceable bulb inside the headlight is available in different wattages.
Replace the bulb with a higher wattage one.
50hm66
Some possible reasons include: New lamp is generic and or has a issue----excessive dust or dirt inside the unit on fans etc.
Some of these units had a feature in the menu for quick on where lamp is lit at low level all the time---this shortens the life of the lamp etc
If you did not have this issue before lamp replaced I would suspect a generic cheap bulb may have been used instead of the Toshiba cartridge / lamp combo which costs more.
With the quick on if the set has it normal time is 20 seconds for screen to light----set WILL DETECT IF LAMP IS NOT COMING UP FAST ENOUGH OR BRIGHT ENOUGH.
Generic lamps (cheap) will never be as bright or last a long as a OEM lamp unit.
Just some thoughts based on your question.
Headlight is not bright enough, possible to replace bulb or light kit or headlight
Before you replace anything make sure that the earth connection to the head light bulb fitting is securely attached on both the bulb and the frame side. Also check that the inside of the bulb is not burnt black from element deposits. If this is the case, the headlight bulb will have to be replaced.
1helpful
My tv not bright enough
i have a mitsubishi i bought a bulb from this dealer and i enstalled it now i believe that the picture isn't bright enough or is it just me? could a bulb not be bright enough that it gives a draker picture
5helpful
3answers
How to adjust the screen brightness form dark to bright
ok bottom left hand side of keyboard there is a key with fn on it hold this down along with other blue keys that have like little suns on them this is your brightness keys
Brightness
since you have moved your tv to 100 have the bulb at the side replace this is the light tha illuminate the screen.good luck.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
