The TV was working great after that I heard a loud noise and all the screen went to lines and then I powered it off and never power on again. The Vizio logo is not powered on. I opened the TV and the power supply looks great as the motherboard I don't see nothing damaged. Please help me!!!
That loud pop was a surface mounted "cap" capacitor blowing up. Look for a burnt spot on the circuit boards inside the TV cabinet, it will be very small so look carefully. They are called "Caps" for a reason.
Aug 26, 2015 - If you see a line on your TV screen it might be the result of several causes. Some might be simple to fix and others may actually require you to replace theTV. Pixels on a TVs display panel are organized in groups of straight vertical lines. ...Notice the line defect above is red but they can be white, green, ...
? 17:05
https://www.youtube.com/watch?v=YUKMl7_19gk
Jul 5, 2014 - Uploaded by bam6972
how to repair vizio lcd tv vertical lines then fail ... I do know quite a bit, not everything but I do know my fair share about tvs. this tv needed a new ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... I have Vizio M470SL. My TV has .... Why does my T.V. suck Don't buy Rca T.V..
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
This may have been the sound of electrolytic capacitors exploding. I would not suggest plugging the set back in until you can have it checked by a qualified TV technician. If you are skilled in Electronics and would like to work on this yourself, you will need:
The schematic diagram, a multimeter, a signal generator, an oscilloscope, and an isolation transformer.
