1. loaded machine as normal and closed door. 2. started cycle and heard a pop as safety switch operated. 3. reset safety switch. 4. started cycle (i.e. press front panel power button) and washed load as normal. 5. when wash over the door would not open after usual delay. 6. started drying cycle and machine spinned as usual. 7. when dry over the door would not open. 8. disconnected power. 9. opened the door by popping cover off interlock and pulling rod. 10. emptied drum i.e. removed clothes. 11. replaced the door interlock. 12. connected power. 13. loaded machine as normal and closed door. 14. started cycle and no operation however door locked. 15. stopped cycle and waited 2 minutes . 16. unlocked door ok. 17. disconnected power. 18. took back panel off. 19. disconnected 2 plugs from circuit board at lower left. 20. connected power. 21. openned door. 22. started cycle and no operation. 23. waited 5 mins. 24. disconnected power. 25. connected 2 plugs to circuit board at lower left. 26. connected power. 27. closed door. 28. started cycle and no operation. 29. rotated control knob full circle and no operation. 30. pressed every control on front panel with no results. 31. stopped cycle. 32. ask fixya.
