Health & Beauty Logo
A
Anonymous Posted on Apr 14, 2016
I have bought a secondhand aquasoothe travelite scooter, but its flashing 8 times, the batteries are fully charged, when i attach the charger to the battery when its attached to the scooter it works ,but as soon as i disconnect charger it just flashes as i said 8 times and doesnt move and battery indicater is at the bottom.
rhodesworks
Level 3:
Top Expert:
  • Master 3,159 Answers
  • Posted on Apr 15, 2016
rhodesworks
Master
Level 3:
Top Expert:
Answers
3159
Questions
Helped
562725
Points
331463
It sounds like the battery is dead, and not accepting/holding a charge. it sounds like it needs to be replaced.
2answers
How often and long do You charge the go go scooter when not being used
If you use your Travel Scooter once a week or less, charge its batteries at least once a week for at least
24 hours.
1helpful
Non runner on 2013 Eclispe Mobilioty Scooter, red light flashing.
U HAVE TO PUT +61 IN FRONT OF NUMBER TRY THIS NUMBER IN STAFFORDSHIRE 01543 570341 THEY M HELP IGHTI just rang this number & it rang 0249624007.Found this scooter repair in Newcastle contact Peter walz,02 4962 4007 Hi again ring this number they can help u with youre problem 0403 666 613..…,or 1800 726 000. good luck. check all connections between motor & controller 2 flashes,,3 flashes motor has a short circuit to a battery connection contact service center,..,.cheers
2helpful
Aquasoothe travelite classic (four wheels)
only thing i would recommend is make sure the bearings are well greased and any other moving part / joints are also well greased, if you are happy to take the tools to it, there should be a barring that might be loosened up, or a couple of lock nuts that could be loosened slightly. this should make the steering much easier.
Aquasoothe travelite scooter, the batteries are fully charged, the battery gauge is showing full, but the battery light is flashing. It flashes 7 times then pauses, we can't get the machine to move or...
Response to similar query in 2011.
http://www.fixya.com/support/t5751777-aquasoothe_travel_lite_instruction
not my words. The link to the pdf for this is http://www.discovermymobility.com/store/scooters/summit-scooters/elite-portable-scooter/manual.pdf
you want page 22.
Problem Check Point
The driving of the wheelchair is too slow or insufficient, the status
indicator lamp flashes slowly Batteries are exhausted and need to be recharged
1 flash The battery needs charging or there is a bad connection to the battery. Check the connections to the battery or charge batteries.
2 flashes There is a bad connection to the motor.
Check all connections between the motor and the controller.
3 flashes The motor has a short circuit to a battery connection.
4 flashes Freewheel is engaged.
5 flashes Not used.
6 flashes The controller is being inhibited from driving; this may be because the battery charger is connected.
7 flashes A throttle fault is indicated. Make sure that the throttle is in the rest position before switching on the scooter
8 flashes A controller fault is indicated. Make sure the controller connections are secure.
9 flashes The parking brakes have a bad connection. Check the parking brake and motor connections. Make sure the controller connections are secure.
The-Active-Light
does not function,
the Battery/
Status indicator
flashes rapidly.
Count the number
of flashes:
10 flashes
An excessive voltage has been applied
to the controller. This is usually caused
by a poor battery connection. Check the
battery packs and controller
connections.
Sorry wasn't sure how much space they give you for answers. :)
2helpful
Mobility scooter will not charge
possible solution, I have had this problem recently ,it was a Aquasoothe scooter,Both batteries were not accepting charge. Had been installed 2yrs replaced back to normal
2helpful
My aunt recently bought a secondhand scooter shoprider us pat no 4798255 without a users manual and the scooter will not charge please could you help?
Kathryn Was the scooter working when she bought it? If the batteries were fully charged and now it won't charge then I would suspect the charger. If the scooter wasn't charged when she got it and won't charge then I would replace the batteries Hope this helps
3helpful
DRIVEMEDICAL PHOENIX 3 WHEEL Just bought it and charged it for 10hours. When I put battery into scooter, all the battery lights come on- 2red 1yellow 2green.....so is it charged? are the connections loose?...
Wez Thats a normal indication of a full charge. The battery level indicator will go down as you use the scooter. Always charge the scooter overnite if you use it a good bit during the day. With new batteries it will take 8-10 charging to break them in and operating at 100%. Always store fully charged and if not used alot charge once a week after you have charged the batteries 8-10 times
Hope this helps
9helpful
3answers
I have a golden companion scooter and it wont move it flashes a green light but i haave no info on where to obtain the trouble codes
The L.E.D. located on the tiller
dashboard will indicate with flash codes what problem is occurring.
L.E.D. Flashes 1 time and pauses, 1 time and pauses…. Batteries are low,
scooter will still operate.
L.E.D. Flashes 2 times and pauses, 2 times and pauses…. Batteries are very
low, scooter will not operate.
L.E.D. Flashes 3 times and pauses, 3 times and pauses….Over voltage to
controller.
L.E.D. Flashes 5 times and pauses, 5 times and pauses….Brake is in the
freewheel position or connection to brake is open.
L.E.D. Flashes 6 times and pauses, 6 times and pauses….Paddle or speed
potentiometer problem.
L.E.D. Flashes 7 times and pauses, 7 times and pauses….Paddle or speed
L.E.D. Flashes 8 times and pauses, 8 times and pauses….Motor
disconnected or faulty.
L.E.D. Flashes 9 times and pauses, 9 times and pause….Controller fault.
I hope this helps they are pretty standard codes I got this from Golden Tech Web Site
1helpful
Do you need to have batteries on charge everynight even if you have not used the scooter as ive been told that with the travelite you do i borrowed one in process of buying it from friend
If you use the scooter then charge it. You need to charge the scooter at least once a week even if you don't use it. More importantly is that you charge the scooter for at least 8 hours at a time. If you charge it less then it will start killing the batteries.
1helpful
Hogh - low speed switch is incorrectly wired , but i dont know how it should be wired - Pride Hurricane scooter
Hi, I take it been taken then, do you get a error codes ?
see below
DIAGNOSTIC FLASH CODES
The diagnostic flash codes for your scooter are designed to help you perform basic troubleshooting quickly and
easily. A diagnostic flash code will flash from the status LED in the event one of the conditions listed below
develops.
NOTE: Your scooter will not run unless the flash code condition is resolved and the scooter has been
turned off, then turned back on.
Any electromechanical device occasionally requires some troubleshooting. However, most of the problems that
may arise can usually be solved with a bit of thought and common sense. Many of these problems occur because
the batteries are not fully charged or because the batteries are worn down and can no longer hold a charge.
FLASH CODE CONDITION SOLUTION
! (1) Battery charge is low. Charge batteries as soon as possible.
! ! (2)
Batteries are too low to operate the
scooter.
Charge batteries.
! ! ! (3)
The scooter’s battery voltage is too
high to operate the scooter, or the
charger is still connected to charger
port.
Unplug charger and/or turn key off, then
back on again.
! ! ! ! (4) Current limit time out.
Turn the scooter off for a few minutes,
then turn your scooter back on.
! ! ! ! ! (5)
The manual freewheel lever is in the
(forward) freewheel position.
Remove the key from the key switch,
then push the manual freewheel lever to
the (rear) drive position, and restart your
scooter.
! ! ! ! ! ! (6)
Throttle control lever not at center
position at start up.
Return the throttle control lever to center
position, turn scooter off, then back on.
! ! ! ! ! ! ! (7) Speed pot error.
Contact your authorised Pride Dealer for
assistance.
! ! ! ! ! ! ! ! (8) Motor volts error.
assistance.
! ! ! ! ! ! ! ! ! (9) Other internal errors.
Regards
GeWiz.
Top Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Health and Beauty Expert? Answer questions, earn points and help others
