20 Most Recent
Golden Technologies Golden CompanioN II - 3 Wheel Questions & Answers
I have a golden companion
The L.E.D. located on the tiller
dashboard will indicate with flash codes what problem is occurring.
L.E.D. Flashes 1 time and pauses, 1 time and pauses…. Batteries are low,
scooter will still operate.
L.E.D. Flashes 2 times and pauses, 2 times and pauses…. Batteries are very
low, scooter will not operate.
L.E.D. Flashes 3 times and pauses, 3 times and pauses….Over voltage to
controller.
L.E.D. Flashes 5 times and pauses, 5 times and pauses….Brake is in the
freewheel position or connection to brake is open.
L.E.D. Flashes 6 times and pauses, 6 times and pauses….Paddle or speed
potentiometer problem.
L.E.D. Flashes 7 times and pauses, 7 times and pauses….Paddle or speed
L.E.D. Flashes 8 times and pauses, 8 times and pauses….Motor
disconnected or faulty.
L.E.D. Flashes 9 times and pauses, 9 times and pause….Controller fault.
I hope this helps they are pretty standard codes I got this from Golden Tech Web Site
8/31/2021 3:28:48 PM •
Golden...
Answered
on Aug 31, 2021
I have a 245 Rascal Scooter. I need to know if I
most rascal 235 and 245 scooters come equiped with power seat height control. you turn the key to the left and then the throttle lever becomes the seat height controller. the seat motor is ditectly uuder front of seat post. if it will not run follow wires to see that they are plugged up good.
2/2/2017 7:56:28 PM •
Golden...
Answered
on Feb 02, 2017
My Scooter will not take a charge!I have put in new batteries.Any help woul
Make sure the circuit breaker hasn't tripped. There is a fuse in line on the 3 pin charge port on the scooter. You have to take all the screws out of the back of the tiller to get to the fuse. You can go on Golden's website and download the service manual. It is a wealth of information.
3/7/2016 11:43:23 PM •
Golden...
Answered
on Mar 07, 2016
Tilt steering stuck in down position.wont tilt forward.
I am sure you have tried this but put it all the way down and let it lock. Then try and pull it back up. The problem will be if it stays stuck. I would wiggle the wheel at the same time. May need a third hand to help.
2/23/2015 6:46:08 PM •
Golden...
Answered
on Feb 23, 2015
How do i fix a tiller that will not lock in places
That is the same problem I had on my Pride Legend Xl. I bought
used. Tiller mechanism switch and cable would not lock the mechanism down below. I tried a few things to just lock it in the upright position permanently, finally I discovered the only way to "lock" the tiller, was to use a huge automotive 3-6 inch diameter
hose clamp, and install it inside the rubber boot at the bottom of the tiller to tighten around the tiller tilt mechanism and prevent it from
tilting, and that has worked for me. The lock mechanisms seem to be prone to failure on some models and the cost of repairing them is very expensive.
11/9/2014 12:25:31 PM •
Golden...
Answered
on Nov 09, 2014
Steering column falls forward . how to prevent.
There is a pivot knuckle located inside rubber boot. This knuckle connects the upper tiller to the steering assembly of the front wheel. There will be a bolt that connects the knuckle. You will need to ensure that is tight along with checking any quick release buttons or levers that allows the tiller to move into different positions.
10/10/2014 11:38:40 AM •
Golden...
Answered
on Oct 10, 2014
Nuts and drive shaft, the
It does not need to be re-threaded you simple need a washer and a nylon nut that fits. If you have damage on the shaft and thread will not accept a nut, then you should call a professional technician to look at it.
9/22/2014 12:25:20 AM •
Golden...
Answered
on Sep 22, 2014
Rascal 245 owners manual
Haveing problems getting the scooter to move all lights are working but will not drive
6/23/2013 2:18:23 PM •
Golden...
Answered
on Jun 23, 2013
Axle makes a noises going forward only sounds like
there is no bushing on my rear wheels axle albeit an older scooter...wheel runs metal to metal on the axle and so...remove wheel and clean an grease the axle an replace the wheel.... probably wouldn't hurt to run a greasy rag back and forth through the wheel a time or two too...Sometime next week. The Maintenance Dude here @ Big Muddy River Apartments will be correcting a dry rear wheel on my old ole Golden Companion II. I had just acquired the thing and almost immediately after I sat on it to take it for a spin. The left rear wheel started acting up. Lucky my power chair guy does scooter repair too, and he told me no bearings in the back wheels. Its metal to metal and removing the wheel an greasing the axle should take care of it, and I havt'a say that was really admirable of him cause he could have clipped me for a service call and a grease job.....the end
2/5/2013 9:39:16 PM •
Golden...
Answered
on Feb 05, 2013
