SOURCE: 4wd_light_keeps_flashing_when_put_in_4h or 4L
Whenever
this warning or any other stays on in the dash it is indicating that
the systems control module has detected a fault, it then disables the
system as long as the light is on. You must now have the dealer hook
up a special electronic diagnostic tool and "scan" the
system for the fault code that is stored for the problem(s)
From N to 4H
Stop the vehicle completely, place the
transmission in "N" (Neutral) and depress
the brake pedal and the clutch pedal fully
(if equipped), then push in and turn the
switch to shift into "4H".
From 4H to 4H LOCK
You can operate the transfer switch either
when the vehicle is stopped or while the
vehicle is moving.
Position the front wheels straight ahead
and turn the switch to shift into "4H LOCK".
If the vehicle is moving, we recommend
that the speed be less than 100 km/h (60
mph) during this operation.
NOTE:
• When shifting between the transfer
switch position and the transfer gear
position is unmatched, all 4WD indicators
will blink and the buzzer will sound.
• If it is difficult to shift between "4H" and
"4H LOCK" while the vehicle is moving,
try accelerating and decelerating your
vehicle several times after turning the
transfer switch. Be sure to wait until traffic
conditions allow you to accelerate and
decelerate safety before using this procedure.
From 4H LOCK to 4L LOCK
switch to shift into "4L LOCK".
From 4L LOCK to 4H LOCK
From 4H LOCK to 4H
vehicle is moving.
and turn the switch to shift into "4H". If the
vehicle is moving, we recommend that the
speed be less than 100 km/h (60 mph) during
this operation.
NOTE:
From 4H to N
64J209
switch to the mark (1) at the left of the "N"
position, and hold the switch in this posi-
tion for 5 seconds until the "N" indicator
blinks, then turn the switch to the "N" position.
When you turn the transfer switch to the
"N" position, "N" indicator will come on with
the buzzer sound.
CAUTION
• Be sure to stop the vehicle completely
before operating the transfer
switch to shift between "N" and
"4H", or between "4H LOCK" and
"4L LOCK".
• Do not shift between "4H" and "4H
LOCK" unless the front wheels are
in the straight-ahead position and
we recommend that the vehicle
mph).
Do not operate the transfer switch
while tires are racing.
• Do not operate your vehicle in "4H
LOCK" or "4L LOCK" on dry, hard
surfaces.
(Continued)
CAUTION
(Continued)
• Do not operate the vehicle while a
4WD mode indicator is blinking
except when shifting between "4H"
and "4L LOCK".
If you operate the vehicle while a
4WD mode indicator is blinking, a
buzzer will sound and the transfer
will shift to "N" (Neutral) to prevent
transfer case damage.
In this case, use the following procedure.
1) Depress the clutch pedal fully (if
equipped) or shift the automatic
transmission gearshift lever to the
"N" position.
2) Turn the transfer switch to the
position previously selected.
3) Operate the transfer switch again.
