SOURCE: optical output on tv through dvd home cinema out of sync
I just had the same problem. I returned it to currys and got an exchange because I thought there was somethink wrong with the surround sound itself. I have just tried , and left for ages as it goes out of sync gradually as you said ,the red/white cables (rca , i think it's called)and it works perfectely. You can find the wire for quite cheap just type it in google.
SOURCE: trouble with speakers (Samsung 2.1) to 52" sony bravia lcd
that is the simplest way. please rate, thanks and have a good day
Testimonial: "very fast, thanks for the help!"
Up front, i copied this from another site, so kudos to the OP there if this works for anyone...
This same problem had been bugging me when I bought my LE37B650,
everyone suggested adjusting the delay time on my AV amp but
unfortunately mine does not have this function.
Anyway I finally fixed the problem using the following steps
Before you start make a note of your menu settings as you will have to reset them after this procedure
Turn off the TV then press Info -> Menu -> Mute in sequence then
turn the TV back on again. This will get you into the secret Service
Menu. Go straight to the AUDIO page of the menu. Don't be tempted to fiddle with things in service menu cos you can end up in a right old pickle!
In the AUDIO page you willl notice that there is a time delay set for
the internal speakers of 100ms but for some reason this is not set for
the external output so all you need do is dial in a 100ms delay there
and that should sort the problem. Well it fixed it for me.
Note that as soon as you enter the service menu, all your other
standard menu settings are lost and the screen will be set to dynamic
for some reason so you have to go through and change everything back
after you have done this.
Hope this Helps
Original link: http://www.hometheaterforum.com/forum/thread/280579/audio-delay-on-samsung-650-lcd-tv
This would suggest that you CAN fix the problem with an analog amp.
Also interested to see if a 2 year old thread is alive!
SOURCE: I have a Samsung hw c-451 sound bar.I have it
Dish doesn't appear to have a code for Samsung receivers but try the Sharp codes listed. Here's a link
http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml#amp
Same thing for the LG remote
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=3252
I recommend connecting your sound bar to your dish receiver as well as to the television. Play around with optical and RCA to see which one you prefer the sound of. The television isn't always the best center channel so you might find that you like this set up better with the dish receiver connected directly to the sound bar. Then you can shut of the television speakers. Some people turn the television speakers back on and leave the sound bar off for early morning breakfast news viewing. Not being sure which dish receiver you're using you might have to indicate to it how you wish to output your audio, or all outputs might be outputting at the same time all of the time.
SOURCE: Sky remote code for new Samsung 4k curve tv
If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
