The only time the Security Code is used is to effect
Remote Access, ie, "call home and manage your
answering machine messages remotely" by pressing
the code numbers while the Greeting is being said....
The Security Code is set on the D1680 from the handset
by this procedure:
press [menu]
scroll to "Ans. Setup"
press [select]
scroll to "Security Code"
press [select]
the code will be displayed, first digit blinking
(enter a new digit if you want to change it )
the code will be displayed, second digit blinking
press [select] (chirp) press [END}
All of the Answering Machine System functions can
be managed remotely, and voice menus are provided
to guide you in these operations.
Entering the model number found on a small sticker under
the battery in the handset at www.manualslib.com will
fetch a free copy of the User's Manual in case the original
has been misplaced.
SOURCE: retrieve messages from uniden 8885-2
As soon as your message starts, enter 0 and your pin (w/in 2 seconds). Then follow prompts. More specifics, see your telephone manual - you can go to www.retrevo.com/support/uniden-tru8885-2
See pg 64-65 and if you need to set pin, pg 25. Be blessed.
SOURCE: Need to change greeting message and where could I get a manual
http://safemanuals.com/ if this helped wish i think it well pleasc let me know i could be of help.
SOURCE: retrieve deleted messages from uniden cordless phone
After its deleted then its deleted forever. These are not like the old answering machines that all you did was pull the plug and plugged it back into the wall outlet to retrieve old messages was were deleted. When digital you can not do that....Sorry
SOURCE: I HAVE A UNIDEN d1680 SERIES PHONE AND WHEN
Try to reset the phone, remove all the handset batteries, disconnect power adapter and let it sit for 3-5 minutes and put back the system. This will remove all the phone memory and clear all the glitches.
SOURCE: How do i reset security code on uniden premium direct phone, so I can get into record greeting.
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
