Computers & Internet Logo
T
Tushar Dutta Posted on Feb 27, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to speed up internet network - D-Link Computers & Internet
DocLab
Level 2:
Novelist:
  • D-Link Expert 199 Answers
  • Posted on Jan 06, 2017
DocLab
D-Link Expert
Level 2:
Novelist:
Answers
199
Questions
0
Helped
123500
Points
205
The speed of your internet is determined by your service provider and their modem. If possible, connect directly to the modem to check the speed. If you suspect you D-Link router is not allowing you to get full internet speed, first a Hard Reboot of you Router and Modem.
If that did not solve the issue, try a known working LAN 5e cable between your modem and router. After you have established it is not a cable issue, do a factory reset.
I had an issue where my speed to the internet modem was fine, but the router LAN connections only provide a faction of the internet speed. After testing cables, etc I did a factory reset and it restored full connection speed on my router LAN ports.
2answers
HOW TO INCREASE SPEED OF 3G BSNL MODEM
Hi, Try with these following tips increase the speed of the modem.
1.) Download and install Ad-Aware, Spybot and latest Anti-Virus.
2.) Change your browser settings to shorten web-page loading times.3.) Close all programs while downloading and viewing web pages.4.) Purchase Modem Booster.
Following these steps may speed up your modem resulting in better internet speed. You can check your Internet speed from www.ScanMySpeed.com before and after preforming these steps.
2answers
Internet speed problem
Use the below steps.
1. Internet Speed Problems caused by Binding too many Agreements on Network Card
Slow internet surfing speed is a usual problem among LAN users because there are too many agreements binding on the Network Card. If a NIC is bound lots of agreements then the computer has to spend more time on identifying which agreement would transmit a certain group of data that passes it. PC users will feel uncomfortable at the moment when they are surfing the Internet. Here is a solution for this situation: a. Use a Network Card to run only PPPOE agreement to connect ADSL; this will provide the exterior connection of internet. b. Use another one to run other agreements in order to boost its performance so that the speed of internet surfing would be improved obviously.
2. Internet Speed Problems caused by Unbound TCP/IP Agreement.
Unbound TCP (Transport Control Protocol)/IP (international agreement) may be caused by reasons as follow: a. the driver of Network Card is installed incorrectly. b. There is a problem with quality of Network Card. c. PCI slot is broken. Solution for this situation: You should uninstall NIC driver in the Device Manager at first----reinstall the driver after you reboot your computer. If you still fail to improve the internet speed with this solution, please change a PCI slot for Network Card or change a new one.
3. Internet Speed Problems caused by low quality of telephone line.
If the phone line is affected by some bad extraneous factors, network device will adjust client access rate automatically and dynamically according by the quality of line and transmission distance. The Internet surfing Speed also will be affected by the export bandwidth, the website line from opponents and the device configuration if you try to visit foreign website.
4. Internet Speed Problems caused by too much installed Internet Explorer plug-ins.
Internet Explorer plug-ins would be installed or loaded on your computer automatically when you open Internet Explorer and visit website. Surfing speed of course will be slowed down by too much Internet Explorer plug-ins. It is highly recommended to use some optimization tools to optimize your speed of Internet and clean some disused Internet Explorer plug-ins to speed up Internet surfing.
The 100m light flashes but the 10m don,t flash even though connected but speed very slow
The speed you are connected to your network at is 100mbs.
the 10m light shouldn't flash unless that's the speed of your network.
the slow speed is probably due to the bandwidth usage to the internet.
if anything else connects the internet on the network it will share the bandwidth. also depends on the broadband speed you are subscribed to.
Load drivers for high speed internet
If you are connecting to the Internet by Network Cable to your Cable or DSL Modem... No Drivers will be needed. The Speed with be established by the Network Card.
2answers
Upload Speeds Slow, Ping High
s it is ur problem of ur LAN card..check the speed of ur LAN card..
1helpful
3answers
We are using 10Mbps internet connection but in speed test it comes out to be 0.17Mbps download speed & 0.01Mbps upload speed what to do
U may try the Google search to increase Your internet speed .its contains the many online tips to increase the internet .And U check Your internet speed from the site ipdetails
1helpful
5answers
How to speed up internet download
maybe..that download and upload speed is controlled by your internet service providor. call them and enquire about the effective speed that they can deliver.
2answers
To speed up internet
there is a utility out there that has a 15 or 30 day trial on the full version then goes to a stripped model called Network Magic. Install that and see what it tells ya then maybe talk to your service provider who knows theres about a bizzilion reasons it could happen
1helpful
2answers
NOKIA 6270 - Airtel GPRS
your nokia 6270 is EDGE enabled phone, that means you must get speed like 100 kbps with airtel gprs[mobile office].but you are getting too low speed its beacause of network there is not EDGE enabled till date, you have to wait for that when they upgrade their network services. so with normal gprs you obviously get slow speed its about 3-4 kbps only. so the thing is you cant do anything other than waiting for service upgradation or change your network with other service provider who provides EDGE enabled network.
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
