Universal EasyCAP USB 2.0 Audio/Video Capture/Surveillance Dongle Logo
Posted on Feb 14, 2016
Howto install drivers - Universal EasyCAP USB 2.0 Audio/Video Capture/Surveillance Dongle
1helpful
Xps driver to eject disks
The old driver, most likely, will not work. Did you do a Win 8 Hardware compatibility test prior to installing Win 8? Is that the only issue? What was the Dell's OS before the upgrade? Take a look at this: http://howto.cnet.com/8301-11310_39-57390888-285/check-your-hardware-for-windows-8-compatibility/
tip
FREE Printer Drivers for Lost Driver Installation Discs
Download Drivers,...
Download Drivers, Software and Manuals for free from the manufacturer website.
Epson Stylus Multifunction Printer/ Copier/ Scanner InkJet
HP Multifunction Printer/ Copier/ Scanner InkJet
Canon Multifunction Printer/ Copier/ Scanner InkJet
Brother Multifunction Printer/ Copier/ Scanner InkJet
Lexmark Multifunction Printer/ Copier/ Scanner InkJet
Remove and Install the Printer Driver for your product:
DRIVER REMOVAL
1. Turn off the printer and disconnect the USB cable.
2. Click the Start button and select Programs or All Programs.
3. Locate and select Printer Software Uninstall.
4. Restart your computer !
INSTALLATION
1. Go to the support website.
2. Select your model and download the printer driver for your Windows operating system.
3. Double-click the downloaded file and follow the on-screen instructions.
4. When prompted, connect the USB cable and turn on the printer. Installation should complete automatically.
Do not reconnect the USB cable until the point in the printer driver installation where you are prompted to check that the unit is on and connected to the computer.
2answers
How to install linux
please refer this address you will get help
http://tldp.org/HOWTO/Installation-HOWTO/overview.html#EASYWAY
Howto instal mi printer
There are drivers available for download in the Lexmark website. Just click on this link: http://bit.ly/cWEM7D. Click on the dropdowns found below the page to choose the operating system of your computer. Hope this helps.
Upgrade my system then audio drivers is not instal showing error
Try updating the drivers instructions here:-
http://www.howtofixanything.co.uk/howto-266.html
If no luck then turn power off and take out the sound card if it's sound straight from the motherboard then post make and model of the PC here and I will locate the drivers for you, thanks.
1helpful
Install xp on notebook
this is the tutorial make xp with sata drivers
contain download link
http://www.howtogeek.com/howto/windows/resolving-setup-did-not-find-any-hard-disk-drives-during-windows-xp-installation/
Vista software download
http://www.p4c.philips.com/files/s/spc700nc_37/spc700nc_37_dwv_eng.exe
Sergio
Todo: Check USB port
Howto:
061027085005_16154.png Refit the USB cable into the port.
061027085005_16154.png Plug the webcam into another USB port.
061027085005_16154.png Use an external powered USB-Hub. Some USB ports on computers do not have enough power to feed USB devices (this mostly occurs with laptops).
061027085005_16154.png Try to install the webcam on another computer.
Todo: Update your computer
HowTo: Update the USB driver in Windows
USB driver update in
WindowsXP
061027085005_16154.png Click Start -> Control Panel -> System
061027085005_16154.png Click the tab Hardware and then click on Device manager
061027085005_16154.png Click at the bottom of the tree on the + sign before Universal Serial Bus controllers
061027085005_16154.png Select the first entry, right mouse click and click on Update driver...
061027085005_16154.png Follow the steps to update the USB driver
Windows2000
061027085005_16154.png Click Start -> Settings -> Control Panel -> System
061027085005_16154.png At the bottom of the tree click on the + sign before Universal Serial Bus controllers
061027085005_16154.png Click on General USB Hub, right mouse click and click on Properties
061027085005_16154.png Click on the tab Driver and click on the button Update Driver.
Todo: (re)install the latest driver
HowTo:
061027085005_16154.png Deinstall any webcam driver (Philips drivers or webcam drivers from other brands you might have installed in the past)
061027085005_16154.png Cleanup the computer with for instance CCleaner (select Issues (1) and click Scan for Issues(2). Fix issues if necessary)
061027085005_16154.png Download and install the latest driver.
Nvidia Quadro4 (128MB RAM) driver required for linux 2.4.20.18.7
hi there..
here is the link for your Quadro 4 Graphics for linux 32 Bit
To download and install the drivers, follow the steps below:
STEP 1: Review the NVIDIA Software License.
You will need to accept this license prior to downloading any files.
STEP 2: Download the Driver File
Download - NVIDIA-Linux-x86-96.43.05-pkg1.run
SuSE users: please read the SuSE NVIDIA Installer HOWTO before downloading the driver.
STEP 3: Install
Type "sh NVIDIA-Linux-x86-96.43.05-pkg1.run" to install the driver. NVIDIA now provides a utility to assist you with configuration of your X config file. Please see Chapter 3 of the README or run 'man nvidia-xconfig' for details on usage. Instructions for those wishing to edit their X config file by hand can also be found in the README.
__________________________________
here is the link for your Quadro 4 Graphics for linux 64 Bit
Download - NVIDIA-Linux-x86_64-1.0-9639-pkg2.run
STEP 3: Install
Type "sh NVIDIA-Linux-x86_64-1.0-9639-pkg2.run" to install the driver, then edit your X config file as appropriate. If you are using a Linux 2.6 based system, type "modprobe -q agpgart", first. See the text README for more detailed instructions.
All the Best.
Was this solution helpful? Show your Appreciation by rating it:
Top Universal Computers & Internet Experts
Paul Carew
vince
 Grubhead
Grubhead
Are you an Universal Computer and Internet Expert? Answer questions, earn points and help others
