Beeps 3 times for so many time then goes to continual beep for many minutes
LG Fridge Door Alarm ' Chris Inch
www.chrisinch.com/blog/articles/show/lg-fridge-door-alarm/
Aug 30, 2006 - It's just too bad I can't live with beeping noises going off every 30 seconds. .... took them a long time and they scratched the paint) the fridge beganbeeping ..... I opened the fridge door to let the alarm sound and then located the alarm..... I can't tell you how many times I've "snapped" since hearing this thing.
FIXED Frigidaire Professional Constant Beeping - ApplianceBlog
www.applianceblog.com/.../17546-Frigidaire-Professional-Constant-Bee...
Jan 15, 2010 - 10 posts - 3 authors
The refrigerator is not refrigerating and I don't here the fan go on or ... the water comes out from the water dispenser and so does the ice. ... Thank You so much! ... The unit is two years old from time of purchase. ... Then to install it you remove the #81 screws here: 11-Controls parts .... All times are GMT -6.
Fisher & Paykel fridge in alarm - Kitchen - Home - Whirlpool
forums.whirlpool.net.au > Home > Kitchen
WhirlpoolJan 24, 2010 - I push the selector button to mute the alarm and then it may not do it again ... I can determine the fault code through the number of beeps/flashes? ... myfridge started beeping every 6 hours abut a week ago. ... posted 2012-Aug-7, 3:17 pm.... If so, defrost the coils behind freezer, you can use a hair dryer to ...
SOURCE: FPCE19TR frigidaire refrigerator/freezer door beeping at odd times
Hello delgrandma
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, your refrigerator has a sensor for when the door is not closed but lately
the beeper goes off at various times and the door is shut. Your husband
has tried to level up the door and you don't see anything keeping the
door from shutting securely. The beeper even goes off in the middle of the night.
This sounds like the alarm switch or sensor is malfunctioning.
Do you have a refrigerator thermometer? You can buy one in the hardware store pretty cheap.
If so put it into the fridge and make sure the temperature is steady and not fluctuating.
If it fluctuating this may set off the alarm if it is a sensor that triggers the alarm due to temperature drop..
Rather than a mercury switch will only signal the false door opening if it is faulted, rather than a warm temperature!
How old is the fridge?
Here is an interesting report I just read!
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Let me know what you decide!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Please remember to leave a rating before you go!
Thank you
SOURCE: E249T Fisher and Paykel Beeps when door opened
Disconnect the Fridge for 5 mins. After that, should be ok.
SOURCE: My refrigerator beeps 5 times every few minutes
The refrigerator is probably beeping because it is too warm. It has a sensor thaat will make it beep to warn you if it gets too warm. After being off for such a long time it will take a long time to get it cold enough again to stop the beeping. Give it time and it will stop.
SOURCE: continual beeping
Hi, welcome to Fixya A very common problem with those fridges actually. Check to make sure the door sensor`s are secure and contacting each other when the door is closed. You can do this by accessing one or both sides of the door sensors at the hinge assembly cover at the cabinet top. There should be sensor`s on either side which sense when the door is closed by "making" with magnets on the doors. They sometimes become loose from where they are held in place and therefore do not indicate the door is actually closed. That is the most likely cause. If this does indeed help you solve your issue please take a moment and rate it accordingly. If it doesn't solve the problem let me know and I'll try and assist you further. Thanks for visiting "fixya" today. good luck. macmarkus :)
SOURCE: The alarm beep which tells you to close
Sounds like you have a bad door switch. Depending on the age of the fridge, it might still be under warranty. If it's not, then you might be able to access the door switch yourself and pull it out & replace it.
Good luck......
