Apple iPhone4 4G iPhone 4 Logo
T
Ted Webb Posted on Jan 31, 2016
Phone screen went off and voice says screen is locked
I locked by messing with settings speach on on so i can hear phone menues phone restarted with screen lock apperi
If you locked it with a password that is what is required to unlock it, If not password protected ,go in to settings and turn off voice menu from there.
tip
Samsung Intensity: How to avoid the voice recognition prompt
The Samsung Intensity has many nice features. It comes equipped with voice recognition software, which many people like. However, for others it is merely annoying. If you keep your phone in your pocket or purse, you might hear a muffled voice saying "Please say a command" from time to time as the phone's voice recognition button is bumped.
Fortunately, you can disable this voice prompt (if you want to) with just a few simple steps:
1. Press the voice recognition button on the upper right hand side of the phone.
2. Press the right options button to go to the Settings.
3. Select Prompts (#5).
4. Select Mode (#1).
5. Select Tones Only (the last choice).
6. Hit OK to save the change.
Now, when you accidentally bump that button, you'll just hear a short single tone, rather than the voice prompt.
If you want to reduce the volume for the voice recognition (either for the voice prompt or for the tone) that can be done easily as well. Follow the steps above to get to the Prompts menu, and select Audio playback (choice #2). Highlight the choice for Earpiece, and hit OK to save your choice.
The voice recognition function will now use the earpiece to play any sounds, rather than the speakerphone, so whether you set it for a voice prompt or a tone, the sound will be much quieter and hopefully you won't even notice it.
You can also lock the phone when you're not using it, which will disable the voice recognition button so you don't have to worry about bumping it. To lock your phone, just hold down the zero (0) key for two seconds. You'll see a message on the screen that the phone is now locked.
How do I deselect allow speech over locked screen
How to turn off Switch Control??? ' Apple Support Communities
discussions.apple.com > Support > Apple Support Communities
Apple Inc.Sep 18, 2013 - To disable voice dialing: Tap on the Settings app. Tap on General. Tapon Passcode Lock. Turn Passcode lock on. Slide the Voice Dial slider to Off.
Locked Windows Phone: things it can still do ' Windows ...
www.windowsphone.com/.../locked-phone-things-it-can...
Windows PhoneFrom the lock screen, just swipe up until you see the keypad, tap Emergency call, and ... Make your choice using the Allow speech above lock check box in Settings ... It has the same functionality as Speech on Windows Phone 8.1, plus the ...
Disable notification content on Lollipop lock screen for better ...
www.techrepublic.com/.../disable-notification-content-on-l...
TechRepublicApr 8, 2015 - If you've found the Android Lollipop lock screen to be a security issue, Jack ... Disable notification content on Lollipop lock screen for better privacy ... He's an avid promoter of open source and the voice of The Android Expert.
Accessibility basics - Android Accessibility - eyes-free
My voice control is on on my iphone 5c i have tried to unlock screen with password to turn it off but it says wrong password and locked my screen
You still can unlock the phone, if you use the password from your apple id. Don't mess up, because you did setup the security to this level and only you can unlock it. Don't get frustrated. Just do what is asked.
If you really don't know the pass code and the password for your apple ID, the only thins you can try is to bring it in an Apple store and after you proved (with an invoice) the phone is yours, they could help.
Remember, Apple tries to protect your phone from being stolen, by improving the security level. You don't need to use the lock screen in the first place, but then you can't complain when loosing the phone it is used by someone else.
Disable lock screen
I believe you need to use 3 fingers to swipe to the right anywhere on the lock screen.
How to deactivate voice command
Double click fast on home button
New voice mail appears on screen
In order to get this off your screen you will have to follow whatever procedure your phone carrier provides. I had the same problem, and went to Comcast Website. I discovered I had one voicemail waiting for me to listen to, once I did, and deleted it, the display went away.
8helpful
2answers
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
