LG 47LN5400 47" LED TV 1920x1080, 120 Hz. HDTV Logo
Stephen Pressley Posted on Jan 29, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need help with my television. The picture has gone dark and I would like to be able to fix it and not buy another television.
I have had it since 06/01/2014 which means the warranty is expired. The picture has just gone bad. The sound is fine. But when I cut the tv on, there is a quick flash then dark screen. I can see a semblance of a picture if I get close to the screen or use a flashlight. My understanding is this might be an LED motherboard problem. If this is an easy fix, I sure would like to know how (in detail) how to do it. I have cut the power to the tv, cable box, wifi, and everything remotely connected. When powered back on, the problem still existed. Thanks, Stephen
Sp Gupta
Level 3:
  • LG Master 727 Answers
  • Posted on Jan 30, 2016
Sp Gupta
LG Master
Level 3:
Answers
727
Questions
5
Helped
144766
Points
3137
Hi Stephen,
This is a case of backlight failure. Some of the LEDs in the backlight array have failed and causing this trouble. To repair it the LCD panel has to be opened and I am sorry You can not do anything about it yourself, because it is a highly delicate job and needs a fair degree of expertise. You will have to handover the job to some good local TV Tech.
Good Luck.
  • Sp Gupta Jan 30, 2016
    Hi Stephen,
    Good Luck.
5 Related Answers
Anonymous
  • 1274 Answers
  • Posted on Dec 12, 2010
SOURCE: I cannot get my television to power on. I have
Hi frank, my name is John. Welcome to FixYa. You need to try, what we call a Cold Start-up. What you do is unplug everything, and let it remain unplugged for one (1) hour. Then plug it all back in the outlet and start it up manually. Thanks for choosing FixYa....John
Back2life Electronics
  • 933 Answers
  • Posted on May 21, 2012
SOURCE: No picture on mu LG television.
Try the old flashlight test, turn off the lights in the room. Turn on the set and flash a bright flashlight on the screen. Do you see the image or is the screen totally black?? If you see the image, then most likely you have a backlight problem. Verify that you have 24V on the power supply for the inverter
gopakumarg43
  • 76851 Answers
  • Posted on Feb 05, 2015
SOURCE: lg led tv backlight
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
gopakumarg43
  • 76851 Answers
  • Posted on Sep 24, 2015
SOURCE: Led tv model Lg55la6205 flashes once when first powered on and won't show lit picture after. Sound is fine. I can see the tv showing live tv with a flashlight. What do I need to do to fix it?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
gopakumarg43
  • 76851 Answers
  • Posted on Oct 20, 2015
SOURCE: I have a LG 47LN5750 that powers on, flashes a good picture for about 1/2 second, then goes dark. Still have sound & can see a picture with a flashlight shining on the screen.
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
3helpful
Sony KDF-E50A10/4 dark picture
Dark picture is indication that tv needs new lamp.
Replace lamp in tv get bright picture, please buy Sony original lamp for good picture in tv.
2helpful
Panasonic tx-32lx60a colour gone all red/dark
Ur Main Tuner signal board is dead.Replaced this board will fix this problems.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
Yesterday the picture was gone...but I can hear the voice. Today the picture is really dark with double pictures. I already place all color option on the top but its still dark, immposible to watch. Do I...
No this set does not have a bulb, it has three crts, one is green, red blue, and if the colors are seperated this sounds like you have an issue with the convergence, this is common and will require service. If you want to attempt the repair you will need to repalce the two stk392 ic's on the left hand board looking from the back. They are not user servicable. If you are not experienced it electroinic repair i would suggust to get it serviced by a pro.
1helpful
TV is dark
you can fix this problem. remove your tv back cover, there is a part called Flyback. attaching to picture tube. it has two probs for adjesting focus and brightness.adjust your brightness porbe.
Why has the picture on my tv gone too dark to
have sound but picture is too dark to watch on tv
1helpful
Dark Color on TV. Can't adjust the color correctly
Having same problem now for a second time on a 57T500. First time was a bad green bulb that was covered under warranty. Only lasted 2 years....currently debating wether to fix or buy a new set. Bulbs cost about $300. Set is only 5 years old, so very dissapointed with quality.
Dark picture image, dosen't respond to briteness control
are you able to see the picture in a dark room ? does it appear bright enough then ? if so the lights behind your screen have dimmed or gone out completely. this may just be the power supply for the lights or your lcd panel may need to be replaced
HitachI HD DIGITAL TV 53"
Good Day;
For dark picture check RP41 heater circuit, 1.5 ohm, may have changed value & clean spark gaps. Good Luck, big IRISH.
Picture is dark
sitnlisten - yes it does appear your pix tube is getting weak,but we may be able to turn up the flyback alittle to brighten up the picture.If you take the back off you will see the flyback-large black unit with a wire going to the round rubber cap on the back of the pix tube.Look at the flyback there are usually 2 adjusters one marked focus the other screen,just turn up the screen a little bit at a time.If you turn this up too much you will wind up with retrace lines on the screen.You may also want to check the pcboard ass'y for a sub bright adjust,and same thing small adjustments.If this don't help your pix tube may be too far gone.I hope this helps. cooltek Feb.1/08
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
