2002 Toyota RAV4 Logo
Joseph Murphy Posted on Jul 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Remove radio How do I remove the factory radio from a 2002 Toyota Rav4?
  • Joseph Murphy
    Joseph Murphy Jul 15, 2009
    To remove the dashboard I just remove the hex allen key screws?
Anonymous
Level 2:
  • Expert 217 Answers
  • Posted on Jul 15, 2009
Anonymous
Expert
Level 2:
Answers
217
Questions
0
Helped
70934
Points
750
Replace the CD player. To pull the plastic baffle off the dashboard: Adjust the heating vents so they point downwards. Grab the plastic bar between the heating vents and the stereo. Pull. Remove the screws from the front of the mounting brackets. Pull out the crappy stereo. Unplug the antenna and the wiring harnesses. Transfer the mounting brackets to your new stereo. Cut off the big wiring harness (unless you're lucky enough to have a replacement stereo that accepts the same kind). Connect the wires to the wires on your new stereo's harness. For more info: check the website: http://tomclegg.net/toyotastereo
Toyota rav4 fuel filter replacement mileage
It's a lifetime filter, there are no service recommendations from the factory
1helpful
How to unlock radio code of rav4 2002
The code is located with the original paperwork/manual provided with the vehicle. If you do not have this, you will need to take the car to a Toyota dealership and provide them with the radio serial number and the VIN.
1helpful
How can I convert my factory installed radio to bluetooth in my 2007 rav4?
Yes you can! Just Google Bluetooth adapter, choose one from Best Buy, Amazon.com, Ebay, etc.
They work WITH your radio, so you don't have to remove it! The instructions are simple, and most of them work decently.
BTW- Check the reviews and be sure to spend enough to get a decent one!
How to remove the ECM located in a 2002 toyota rav4
The ECM located behind the glove compartment door, remove the glove compartment you will see the ECM.
hope this can help
Toyota Rav4 cd multichanger??
is it in the unit itself have a look carefully if theres a load button on the unit they go into the unit if theres no button indicating this look hard for the changer should be in dash in the unit itself
2002 Toyota Rav4 remove door panel
There are some hidden screws around the door handle but you get under the panel and yank hard to pop the fasteners. Also remove the black piece behind the mirror. Alot of times it is seperate. 3 screws behind that and the connector and you are done.
1helpful
2answers
Radio
take vehicle to toyota dealer as the panel contains more than the radio it also contains other bits,any attempt to remove the radio and the other bits will cause the engine immobliser to cut in,be warned
Top Toyota Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you a Toyota Expert? Answer questions, earn points and help others
