Turn the main power to the unit off, leave off for about 20 seconds then turn back on. Unit should restart. The blinking light is a fault light that can be reset by turning main power off. Most times it will restart no problems but if the fault re occurs there is a problem with the unit itself. If the fan starts and runs for around 4 minutes on cooling mode then stops and blinks there is a problem with the outdoor unit.
blinkin red light usually means hardware failer the only 2 easy tricks to try that wont void your warrenty is #1 remove the hard drive and boot it up without it and see if it boots and says no hard drive then shut it down and plug the hard drive back in if it works now then was just a drive error if it goes back to blinkin you have a bad drive.
#2 the fan test that also seems to clear any over heating or other blinkin light problems --- turn the ps3 off for 40 seconds by the switch on the back then hold down the eject button and flip the power switch back on while still holding the eject button and see if that clears it.
This seems to be a common problem. I have the same issue. Repair man says its a power supply (he thinks). When the lights start blinking, press the power button on top of the tv (not the remote) and most of the time it will come on and work. I am going to try to replace my power supply and see if that fixes the issue. If so, I will update this post.
unplug your printer try to move the ink case manually. if you could remove the ink cartridge, then clean the contacts both on the cartridge and case. return the cartridges then move the case to its original location plug
This maybe a solution. I had the same issue just now. Pulled battery, put back in, placed on dock, and still blinking red. So I removed the camera from the dock, pulled battery, put same old battery back in, placed on the dock and turned the mode switch on right away before it started blinkin red. It seems to be charging now with one bar and has not gone blinking red for 15 minutes.
I was outside with the camera in 10 degree weather taking pics of my dogs but had been inside for 20 minutes before placing it on the doc. I think something may have happened with the charging circuit and turning it on right away with it on the doc may have reset the charging. Try it. Hope it works for you.
MI PROYECTOR PANASONIC PT-LC50U ,SOLO ENCIENDE DE 2 , 10 NINUTOS LUEGO SE APAGA Y SE ENCIENDE LA LUZ O SALE LA LETRA L-n QUE DEBO DE HACER POR AQUI NO HAY CENTRO TECNICO ..
MI CORREO ES : [email protected]
gracias por darme solucion.
